Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - I need help mounting a body to frame where it does not belong! (pics inside)
Old 11-20-2007, 12:04 AM
Dragnfyr Dragnfyr is offline
Looks like the only mount that is really done badly (not counting the general use of hockey pucks) is the stack of hockey pucks... Personally, I would do away with the stack and make a box that comes off the body down to the original frame mounting point you see in that picture... I would also undo the solid mounts for the bed and add a rubber mount of some kind (I always used c4 transmission mounts myself) between them and the bed, otherwise you will eventually end up with stress cracks where the bed was welded to the cab...
