Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - I need help mounting a body to frame where it does not belong! (pics inside)
Old 11-25-2007, 09:43 AM
Dragnfyr Dragnfyr is offline
Originally Posted by fiscus
I like that transmission mount idea it seems like they would be easier to work with than normal body mounts. Do you think a mount like this would be good? (1980s GM trans mount)
I'm thinking this type of mouting won't be as fail-safe though, there is a possibility for it to rip right out?
That is probably as strong or stronger than the original mounts and should be fine... Remember the stress will be divided between all the mounts (5-6 per side it looks like) so unless you hit something that tries to lift the body off the frame you probably wont put that much stress on the mounts...
