i need help with my 700r4 - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-11-2012, 07:29 AM
i need to know why my 700r4 trany is not shifting in to drive or revers it dont shift at all
Old 09-11-2012, 11:05 AM
SSedan64's Avatar
Give some more Info.
Trans mileage?, Rebuilt? Fluid color/smell? etc..
Old 09-11-2012, 02:04 PM
the trany only has abut 3,000 miles on it and is not rebuilt trany fluied is red and it was working fine then all the sudden it started to reave really high and i was slowing down while it was reaving
Old 09-15-2012, 08:55 AM
TexasT's Avatar
Did you ever wonder?
Last journal entry: A little follow up
so, you have a 700r4 or a 4l60E? 3k miles on a non rebuilt 700r4 sounds suspect. More background please.
Old 09-15-2012, 10:13 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
easy item to check is the TV cable. If the TV cable end was disconnected , the transmittin would shift late like the throttle was Wide open
700r4 Jethro77 Introduce Yourself 1 08-17-2010 03:30 PM
700r4 Ted Couch Transmission - Rearend 10 01-27-2009 12:33 PM
Removing a 2.8/700r4, Install V-8 with 700r4 1230firebird Transmission - Rearend 4 09-17-2007 05:17 PM
What are the parts in a 700R4 2-3 TransGo shift kit 700R4 2-3 AngliaBob Transmission - Rearend 3 04-23-2005 11:25 PM
700r4 stuartc Engine 1 10-23-2004 10:40 AM
