We're winning the case!
Hotrodders Bulletin Board > Tech Help > Suspension - Brakes - Steering
  #1
Old 11-26-2006, 09:49 PM
lovethehotrods lovethehotrods is offline
I need help with my breaks,swap drums to discs 1974 chevy nova
hello I need help .I'm going to swap drums breaks for dics breaks on my 1974 chevy nova, I need to know what do i need for the swap.I went to the local junk yard,I got some dics breaks from a nova i don't remember the year that i got the breaks from, but they are from a nova, i 'm sure they are from the 70's nova,do they breaks just bold right on? or do i need to do some thing else? thank you every one,
Hugo.
Old 11-27-2006, 02:57 PM
johnsongrass1's Avatar
johnsongrass1 johnsongrass1 is offline
Race it, Don't rice it!
I don't believe the ball joint are different. Should bolt on cept for the brake line might need changing. The master cylinder will need changing or at least a appriopriate proportining valve.
Old 11-27-2006, 07:35 PM
CDJr's Avatar
CDJr CDJr is offline
Experienced Amateur
CDJr's barnstar
Wiki editor
Last wiki edit: Automobile body and frame rotisserie
Wiki Edits: 2
I hope it was from a 74 or older, cuz I think 75-up are different.
Old 11-27-2006, 08:06 PM
poncho62's Avatar
poncho62 poncho62 is offline
poncho62's barnstar
Wiki editor
Wiki Edits: 5
You need to change the spindles. That is the part that the ball joints are connected with. Also, you need the caliper brackets that attach to the spindles. Also, get the master cylinder and proportioning valve from the same car.
Dont know if the 75s and up are different.........
Old 11-30-2006, 08:12 PM
jimfulco jimfulco is offline
'75-up are definitely different.
Find a '69-'74 Nova or clone, '69 Camaro/Firebird, or '69-'72 Chevelle or clone. Get the spindles, calipers, caliper brackets, rotors, backing plates (AKA dust shields), master cylinder, proportioning valve, and all associated hoses, tubes, and hardware. Some of these are available at an auto parts store, but caliper brackets, backing plates, spindles, and hardware are not.
Chevelle/clone steering arms should NOT be used, and I think their calipers may be a bit different. Steering arms from others are fine, but be sure the lengths match on left and right. About three different lengths were used, and left must match right. Shorter arms will quicken the steering, and will increase effort, especially with manual steering. Longer arms, vice-versa.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "I need help with my breaks,swap drums to discs 1974 chevy nova"
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 47 05-01-2009 11:14 AM
1962 chevy nova straight six fresno1970 Electrical 3 01-07-2003 09:40 PM
Suspension/brake issues arising from putting a bigblock into Chevy Nova Tyrfin Suspension - Brakes - Steering 1 12-28-2002 05:50 PM
1975 Chevy Nova SS pinstriping kalong12 Body - Exterior 3 11-04-2002 02:28 PM
Stereo for 1963 Chevy Nova Chadwick Interior 5 04-29-2002 09:25 AM
