I Need Help With My Chevy 327, broken piston
Hello to all ,
I have a 1967 IMpala and i just rebuilt my 327 engine. It ran fine but i tore it apart again and put a cam in it with new timing gear and chain and valve springs. Now when i try to crank it , its very slow like its dragging. But when i pulled the spark plugs out it cranks fine. i Loosened all the valves just to make sure they were tight but still the same barely cranks. ANY HELP ANYONE!!!!!!! |
do a compression test to check cylinder pressure. pull all plugs and test one cylinder at a time.
what cr? what cam? got a good heavy ground wire on the engine? |
recheck your timing
Hi,
Sounds as if the valves were not adjusted correctly, or the timing is off. Rich |
This is my first engine being rebuilt what do you mean check the ground???? I have the engine on a engine stand. When i pulled the spark plugs out air comes out from each hole. How will i know if the distributer is off?
if you loosen them they won't open & let the pressure off,
thus slow cranking. http://www.classiccarauto.com/impala...t_valves.shtml |
You'll find lots of links here for finding TDC. Then, set your distributor so that the rotor is pointing toward the number one wire within the cap.
A good trick, if you are still using points, is to set the enigne at the static timing value (say, 8* BTDC) then rotate the distributor by hand, with the ignition on, C'CW until the #1 plug fires (keep the plugs out of course). That should be where you want it timed. Pat |
In my opinion you need to check the link & adjust the valves
as per instructions, to just tighten them down isn't gonna get it. http://www.classiccarauto.com/impala...t_valves.shtml |
move the ground to the engine, make sure the connection is clean & tight.
Are you trying to start this engine or are you just using the starter to turn it over?
Start the motor
| All times are GMT -6. The time now is 10:04 PM. |
