I Need Help With My Chevy 327, broken piston - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-19-2008, 01:37 PM
Hello to all ,
I have a 1967 IMpala and i just rebuilt my 327 engine. It ran fine but i tore it apart again and put a cam in it with new timing gear and chain and valve springs. Now when i try to crank it , its very slow like its dragging. But when i pulled the spark plugs out it cranks fine. i Loosened all the valves just to make sure they were tight but still the same barely cranks. ANY HELP ANYONE!!!!!!!
Old 08-19-2008, 01:45 PM
do a compression test to check cylinder pressure. pull all plugs and test one cylinder at a time.
what cr?
what cam?
got a good heavy ground wire on the engine?
nitro_baller4692's Avatar
floppers forever
recheck your timing
Old 08-19-2008, 01:48 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi,
Sounds as if the valves were not adjusted correctly,
or the timing is off.
Rich
Old 08-19-2008, 01:54 PM
This is my first engine being rebuilt what do you mean check the ground???? I have the engine on a engine stand. When i pulled the spark plugs out air comes out from each hole. How will i know if the distributer is off?
Old 08-19-2008, 01:56 PM
Originally Posted by richard stewart 3rd
Hi,
Rich
I loosened them up so there is no tension on them
Old 08-19-2008, 01:58 PM
if you loosen them they won't open & let the pressure off,
thus slow cranking.
http://www.classiccarauto.com/impala...t_valves.shtml
You'll find lots of links here for finding TDC. Then, set your distributor so that the rotor is pointing toward the number one wire within the cap.
A good trick, if you are still using points, is to set the enigne at the static timing value (say, 8* BTDC) then rotate the distributor by hand, with the ignition on, C'CW until the #1 plug fires (keep the plugs out of course). That should be where you want it timed.
Pat
Old 08-19-2008, 02:03 PM
thus slow cranking.
when we partially tightend the valves it was still doing the same thing. Is there anything else it can be. First time builder so any help will work
Old 08-19-2008, 02:15 PM
In my opinion you need to check the link & adjust the valves
as per instructions, to just tighten them down isn't gonna get it.
Old 08-19-2008, 02:17 PM
Ill try that would the ground make a difference i have engine on a stand and i have a wire to the battery and one to the stand
Old 08-19-2008, 02:20 PM
move the ground to the engine, make sure the connection is clean & tight.
Old 08-19-2008, 02:35 PM
I have a wire to the battery and one to the starter. An then i have another one to the ground to the stand and the othere side to the battery. Thats fine right
Old 08-19-2008, 02:44 PM
Are you trying to start this engine or are you just using the starter to turn it over?
Old 08-19-2008, 02:47 PM
Start the motor
Chevy 327 with a 3.48" stroke??? Chevelle Crazy Engine 9 01-12-2007 11:52 AM
Engine build ideas Rug Engine 23 12-25-2006 02:39 PM
Need One Piston For 348 Chevy JDUM Engine 9 01-06-2006 05:42 PM
Fan hit upper rad. hose!! mustangdude947 Engine 14 08-19-2004 04:52 PM
302 piston dim. compared to 327 piston Dave Y. Engine 2 09-25-2002 09:55 AM
