I need help with my fuel cell cap - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-11-2008, 06:10 PM
My gas tank was pretty bad when I dropped it, so I decided to go with a fuel cell in the trunk. Everything is connected and I added fuel with a couple of 5 gallon jugs, but I am having an issue sealing the cap of the cell. Any tips? It seems the rubber gasket around the cap is a tad loose, and when I have it in the open position so the tabs align, I put it in the cell so the tabs align, but then cannot push it down to allow me to turn it because the gasket stops it from going any lower. If I remove the gasket, it goes in fine, so I know it is an issue with the gasket.
I was hoping maybe someone had a tip or two in closing these damn things. It is an aluminum cell, with a plastic cap (Jegs fuel cell).
Thanks.
Old 05-11-2008, 08:14 PM
Vortech 4.3's Avatar
jack of all trades
i was having a BAD problem get my cell cap off. i ended up having to trim the tabs to make it fit better. maybe you are having the same problem, but in reverce ?
Old 05-11-2008, 08:40 PM
Hmm, good point. What is weird is if I take the gasket off it spins fine when I go to lock it. The gasket itself is almost so tight that it is stopping me from pushing the cap down and spinning it. I have to see, maybe the gasket shifted and is not seated correctly.
Old 05-12-2008, 08:54 PM
jack of all trades
i took my gasket off, to diagnose my problem. and the cap worked perfectly. gasket back on, and i nearly couldn't get the cap off. what i did, was to clearfully, with a dremel, take a few to several .001's off parameter of the tabs on the cap.
take the ring off the cell. now test fit the cap in it. you should be able to see what the hang up is.
Old 05-12-2008, 09:18 PM
Good idea about taking the ring off, much easier to really get a good view of the the hang up is.
I see that Jaz and others sell filler attachments that have a basic screw on cap which would be much easier, just not sure if it is NHRA legal or not. Plus I have a Jegs cell, so not sure if all 12 bolt cells have the same bolt spacing.
Old 05-14-2008, 07:00 AM
Would it be an issue if I took the gasket off and close the cap just to fire the motor? I wanted to move the car out of the garage and won't be able to mess with the gasket issue until next weekend.
Old 05-14-2008, 09:13 PM
jack of all trades
i highly doubt that would cause a problem. unless your idle is so loppy that the car shakes
Old 05-15-2008, 05:52 PM
That won't be a problem, plus I only have 1/3-1/2 tank.
I just didn't know if the fuel system gets pressurized or not and if it would be an issue with a good seal by taking the gasket off.
Old 05-17-2008, 07:54 AM
jack of all trades
the cap is vented. the only pressurized systems i know of, are the OBDII systems.
Old 05-26-2008, 08:24 AM
jack of all trades
did ya fix it ?
Old 05-26-2008, 08:41 AM
Yes. Thanks for all your help. I took the cap off and got a full understanding how it works. For some reason I thought the entire cap spun, not realizing it was just the 1/2 that spun to lock it. With a little pressure, I was able to spin it and lock it. I tried it a few more times and it seems easier. Either I just needed to understand how to do it or since it was brand new it just needed to loosen up a bit.
Old 05-26-2008, 09:06 AM
jack of all trades
. it will probably get easier as you use it.
carburetor leaking; fuel tank needs cleaning islandman General Rodding Tech 7 03-17-2007 07:03 PM
!!!!! HELP - CARBURETOR LEAKING & FUEL TANK NEEDS TO BE CLEANED!!!!!!!!!!!!!!!!!!!!! islandman Engine 3 03-17-2007 04:36 PM
How Much Foam to put in a Fuel Cell??? texastomeh General Rodding Tech 1 11-28-2006 12:05 PM
Fuel Cell placement. rhodeislandvolvo General Rodding Tech 3 07-27-2006 09:53 PM
Plumbing for a fuel cell cboy General Rodding Tech 2 12-21-2004 04:07 PM
