I need help picking a rear end - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-08-2005, 03:33 PM
coop_01's Avatar
New Member
I have a 1997 s-10 with a 350 & 350turbo tranni. & I have 3 different rear ends & I need help choosing one to use
Please no amature responces
ok the first one is the stock s-10 rear end its 4:10 gears,
& then I have a posi. 3:73 & then the one thats in it now whitch I think is doggy as hell is a 3:42 or some thing like that. as you can tell im not much on rear ends
but I need some help making this thing rip down the road like it should
Old 02-08-2005, 03:42 PM
willys36@aol.com's Avatar
Wiki Edits: 21
The best all-round range is 3:54 to 3:70. Lower than that and you can't go very fast w/o th engine screaming and high than that and throttle response gets anemic.
Old 02-08-2005, 05:53 PM
Ghetto Jet's Avatar
pic of my Cobra should be here
Last journal entry: Lets Get Started With the Improvements
What size tires are you running in the rear? And how much horsepower are you putting out(approximatly)?
Old 02-08-2005, 06:23 PM
snod83's Avatar
I would not use the stock 4.10 from the s10 because the stock rears are not very durable, I have a 2000 s10 with the 4 banger and 90000 miles and the spider gears are showing significant wear, I would be worried if it weren't only putting out like 100 hp! hahah... but seriously, I would look into getting a 10 bolt or even a 12 bolt. You may look into the Camaro rears, they are pretty durable, and should be close to the right width.
Ryan
Old 02-08-2005, 08:03 PM
coop_01's Avatar
New Member
its just a stock 350 with an intake & holley carb for now but Im about to drop in the ground pounder my 383 stroker Im just sceptical on buying the holley ram jet injection system for it its what i want I have read all about it but I would like to hear from some one that has one
my rear tires are 255 50s
