Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - I need help with PPG OMNI SV MP 282 Primer
Old 08-23-2010, 08:59 AM
Hotbo Hotbo is offline
Originally Posted by Str8tJacket
Hello,, gonna shoot some Omni 2K, primer. I have looked everywhere for mixing directions.I assume that it's 4 to 1.
A customer brought the primer for me to use and now after searching I see basically one site about it,,that it's discontinued and no other info.
What I have gathered is that it isn't for bare metal.
Can anyone with experience with this primer help me? ,,,Thanks.
i use it in my body shop all the time,im not aware of it being dis?
i buy it by the gallon all the time.
it mixes 4-1 and you can reduce it 4-1-1 if not using it as a total fill primer.
it sands great and the dry times are decent.
i use the MH283 in all around weather,in hot i use the MH284.
i haves used this primer for around 2 years(everyday) and have had great results and it doesn't shrink bad either.
hope this helps,Travis
do not use direct to bare metal,epoxy first
