i need help realy bad - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-02-2005, 03:49 PM
wrestlingclub142's Avatar
i have a 93 dodge Dakota with a 3.9 v6. my problem is that i have no power to the coil or the feul injectors. i bought a new computer for it thinking that it went bad but still nothing changed when i installed it. can someone please help i have a car show tomorrow.
Old 09-02-2005, 04:31 PM
docvette's Avatar
Wiki Edits: 12
Fuses
Doc here,
First off , let me make it clear , I am NOT a Dodge guy... so my answer is pointed toward the generic...
But if you are experiencing power loss to the Coil and Injectors... Check your fuse panel for fuses marked "Inj" "ECU" ECM" or "Computer", If those are good...
Confirm if it is power or pulse your losing..at the injector, one side will be +12 volts measured to ground with a DMM, the other one will show a Minus pulse (if your DMM is fast enough) or a -3 to 5 volt pulse, you may need a noid light for this....
If the 12 volt side is missing, you need to track fused power source..and the wire between the injector and fuse panel...
If the low pulse is missing you need to check the wire between the computer and the low side of the Injector...whatever you do...DO NOT HARD ground this line! you will damage the computer and injectors...The pulse is lower than ground and VERY low current and buffered to keep it that way.
What I see happening is this: you have lost coil power , for some reason...this sets up the spark framework for the the dizzy and part of the Dizzy output is a reference pulse going back to the computer to "Sync" Injector pulses to the injectors from the Dizzy..No spark..No reference..No Injectors..
Get the coil working FIRST..try a jumper from the battery to the hot side of the coil and crank it..does spark return? If so check that wire and it;s power source..
If not..replace the coil with a known good one..try again..does spark return? If so try and start it...It SHOULD fire..
If not , you may have other damage to the reference pulse side or Injector pulse ..check these wires going to the dizzy and injectors
from the computer for continuity..
That should get you running..
Also does this have a Cam position and crank position magnetic pick up?
I think Dodge uses the extensively..and they (the crank position) fails Rather frequently..
If you have them check those while checking for the no spark issue, however if it's a NO POWER situation to the coil, I doubt this will be the cause..these will kill the spark side only..
Doc
Old 09-02-2005, 05:06 PM
ok i checked the fuses none was blown. i jumped the coil and it did get spark and so did the injectors. then i tryed starting it again and it still would start it just crank over. so what do i do now
Old 09-02-2005, 05:25 PM
ok does anyone have a shop manual for my dodge and that can scan and email me the wiring diagram for my dodge cause it still won't start and now the fuel pump won't kick on. my email is EBWSnightmare@aol.com thanks
Old 09-02-2005, 06:22 PM
73oldsman's Avatar
I don't have a copy of the diagram you're looking for but maybe someone on this forum, http://www.dodgeforum.com/ or more specifically this, http://www.dodgeforum.com/forumid_28/tt.htm, can help. Just an idea. Good luck!
Old 09-02-2005, 06:47 PM
docvette's Avatar
Wiki Edits: 12
Schematic
Doc here,
Here ya go my man...
Or you can go here to download it yourself...
http://www.autozone.com/servlet/UiBr...3d80113bc2.jsp
Hope it helps..
Doc
Always see the Good in the Bad k2mooch Hotrodders' Lounge 3 03-31-2004 11:11 AM
I need my bad luck to go away..... onebadmerc Hotrodders' Lounge 5 01-23-2004 09:08 PM
is this repetitive bad luck or what? 71gtx Engine 4 11-18-2003 08:19 PM
bad starter? (revised) 69 chevelle malibu 307 malibuman Engine 7 10-30-2003 09:53 PM
how bad is it to ride on bad akm Suspension - Brakes - Steering 5 05-13-2003 09:28 PM
