I need help with small block engine ID chevy
I have a 350 but i'm not sure of the date it was manufactured and where, if you can help please give as much info as possible. I did look on several web sites and had no luck. The numbers are VA065270.
Thanks, jklmbrand. |
I have found Mortec.com to be very informative on finding dates and numbers on Chev engines. Mike
here's a PAGE u can look through that may help u.......joe
Block info
I tried that page and no luck, thanks Joe.
The date code should be just above the bellhousing, If the engine is stilll in the car it makes it a bit harder to see the stamping.
On the back of the block there should be the block code and just over a bit from that should be the date code. |
Thanks for the help 58chev
I will look at that location.
Look for stamped alphanumeric at the front-right deck,near the gasket.
Thanks,
I found it and I now know the engine .
| All times are GMT -6. The time now is 07:47 PM. |
