I need help with small block engine ID chevy - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-27-2006, 06:56 PM
I have a 350 but i'm not sure of the date it was manufactured and where, if you can help please give as much info as possible. I did look on several web sites and had no luck. The numbers are VA065270.
Thanks, jklmbrand.
Old 08-27-2006, 07:12 PM
coupster's Avatar
I have found Mortec.com to be very informative on finding dates and numbers on Chev engines. Mike
Old 08-27-2006, 08:56 PM
TooMany2count's Avatar
A Half Crippled Old SOB....
Last wiki edit: GM RPO build codes Last photo:
Location: Cahokia,IL..... Donate Blood Products & Sign your DONORS CARD
Wiki Edits: 5
here's a PAGE u can look through that may help u.......joe
Old 08-28-2006, 06:20 PM
Block info
I tried that page and no luck, thanks Joe.
Old 08-28-2006, 08:53 PM
58Chev's Avatar
Building a 10 footer.
Last journal entry: No more room in my garage.
The date code should be just above the bellhousing, If the engine is stilll in the car it makes it a bit harder to see the stamping.
On the back of the block there should be the block code and just over a bit from that should be the date code.
Old 08-29-2006, 05:43 PM
Thanks for the help 58chev
I will look at that location.
Old 08-29-2006, 06:42 PM
Look for stamped alphanumeric at the front-right deck,near the gasket.
Old 08-31-2006, 05:36 PM
Thanks,
I found it and I now know the engine .
small block chevy engine id code help princesswz Engine 21 01-03-2015 11:15 AM
Why I have grown to hate the Small Block Chevy..... an essay Centerline Hotrodders' Lounge 316 02-08-2012 10:46 PM
chevy small block possible low oil pressure? ruski Engine 24 04-24-2006 09:18 PM
small block engine rebuild 74camaro Engine 2 04-06-2006 05:08 PM
6" rod small block chevy engine s22479a Introduce Yourself 1 11-13-2004 09:02 AM
