I need help with stained white letter tires - Hot Rod Forum : Hotrodders Bulletin Board
Closed Thread
Old 12-20-2011, 05:45 PM
We received a large amount of white letter new car take offs. These were stored by stacking. Now the white letters are stained from the oils in the tires and have turned the white letters black. Anybody have a solution?
Quick reply to this message
Old 12-20-2011, 05:54 PM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
I would use westleys bleche white , it's good stuff
Old 12-20-2011, 06:00 PM
techinspector1's Avatar
Wiki Edits: 326
I've seen fellows grind the black off tire sidewalls to make whitewalls out of them, so I suspect that a good hand-held grinder with a course disc on it would cut off some of the material down to pure white and do the trick.
http://www.youtube.com/watch?v=yXm0ZTxRrTU
Old 12-20-2011, 06:02 PM
poncho62's Avatar
Wiki Edits: 5
SOS pad.....
Old 12-21-2011, 01:01 PM
Good call poncho.....SOS pads....I'd try that before grinding
Old 01-27-2012, 11:29 PM
i know this is gonna sound funny to you but when i was kid my dad had this caddilac with real wide white walls on them and when we washed it i always wondered what he cleaned the white walls with. it was a smooth rock yeah a smooth rock and as i got older i tried it and it works what i do is spray some purple power on the letters and rub with the rock and its like rubbing 2 erasers together and you get the whitest letters youll ever see FOREAL TRY IT
Old 01-28-2012, 02:30 AM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
Originally Posted by poncho62
SOS pad.....
x2.... actually x1000.
One SOS pad will make 4 tires brighter than they were new.
If you have 10 tires, the SOS pad is worth it. If you have 100 tires, I might just use a palm sander (random orbital) and buzz them clean with some 100-grit paper.
Old 01-28-2012, 01:18 PM
LATECH's Avatar
I have had great results with westleys "bleach White" later on found out it is mostly bleach, so use the bleach , get some from the laundry room, save your money.Scrub em with a brush and bleach.
I have in the past , painted the letters with White latex house paint, when cleaning them didnt work. Use an artist brush, stay inside the lines(LOL)
It is made for outdoors, it is stunning white and being Latex, it likes rubber and seems to live there a good while.
Call it funky or just plain nuts, but hey it works.
Old 01-29-2012, 10:59 AM
caminoguy's Avatar
I detail limos for work. (lincoln town cars) and a lot of the drivers are curb killers. We get this stuff from Allied technologies called Whitewall NL. dilute it 6:1 with water and spray it on. let it sit for a second, scrub with a wire brush. stuff comes right off. Its VOC compliant as well.
Old 08-21-2014, 03:35 PM
Last journal entry: https://www.facebook.com/pages/1941-Chev
I’ve used MWWCK and it works like a charm.
I bought it on eBay and I think they still have the product up
Mikes White Wall Cleaning KIT Hotrod Ratrod Classic CAR MWWCK | eBay
Old 08-21-2014, 06:05 PM
Northstar T's Avatar
Gone sailing
Go to your local Dollar Store and pick up a spray bottle of LA Totally Awesome in the cleaning products. best stuff I've ever found for RWL and it's super easy. when I'm done washing the car I spray some on the sidewalls. by the time you've sprayed all four you can do a quick once over with a damp scrub brush. doesn't take much at all, but helps to get things working. you'll immediately see the dirt being pulled up out of the sidewalls. just hose off the crud and be on your merry way. sounds goofy, but believe me, it works "awesome" . makes a great cleaner for under-hood maintenance cleaning also BTW and will NOT harm aluminum parts etc.
Russ
Old 08-21-2014, 07:09 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
this is an old thread. The original poster has not logged in since 2011
Closed Thread
Stupid Raised White Letter Question daveh Hotrodders' Lounge 19 01-26-2011 02:19 PM
raised letter tires rovert General Rodding Tech 3 05-15-2008 07:14 AM
White Wall Tires SNAKESRED Introduce Yourself 3 01-07-2005 12:29 PM
widewhites made from white letter tires satan's ride Introduce Yourself 1 12-17-2004 04:41 PM
White Wall Tires JOgo General Rodding Tech 4 02-09-2003 06:22 AM
