I Need input on gear ratio & tire size
Here's what I have:
86 swb 350 flat tops pistons Edelbrock rpm air gap intake vortec heads comp xe268 cam long tube headers 2.5" flowmaster super 44's Stock 350 tranny Here my problem: The truck was an original 305 with 2.56 rearend. I just had a 3.73 posi unit installed now the truck is screaming at like 50 mph. I dont have a tach so cant give rpm numbers and i need to change my speedo gear so mph is off. im running 22" rims with 305/40/22 tires. I went with a 3.73 cause of the bigger rims and tires and I plan on either going back to my stock rallys or down sizing to 17's or 18's. I cant even image how bad it would be if I had the smaller wheels on it right now. any input on why the truck is screaming at such a low speed of only 50-55 mph. THANKS IN ADVANCE!! |
i had intentions on going with a 700r4 but turns out the tranny was bad.
You need to get a tach. Then use an online calculator to see that it agrees w/what the rear gear is supposed to be, and that the torque converter or tranny isn't slipping excessively. BTW, the nominal diameter of a 305/40R22 tire is about 31.5"- so it's a "big" diameter tire, relatively speaking. Last edited by cobalt327; 07-05-2011 at 10:13 PM. |
You can go to 4lo.com and they have a ratio calculator.
(New tire height / old tire height) x old gear = new gear example ( 32 / 28 ) x 2.56 = 2.92 So as you can see a 3.73 would be a bit drastic. |
OTOH, there are a LOT of guys running non OD trannys w/3.73- and deeper- gears. It just depends on your tolerance to it and how much highway driving you do. |
you have to get off the line too. anything you give up on top end will make you pay for it on the bottom end. for a 31 inch tire i dont think you are too far off the mark. my ol bronco had 3.50 gears with a 33 inch tire and seemed just right. with 35's it was a dog on take off. btw 3:50 was stock in many 4x's
but i know what you are talking about believe me. i have 4:56's now and a 35 inch tire so i am limited to going about 60-65 on the freeway at around 2800. and i could actually still be happy with 4:88's and just going 60. i would want bigger tires tho to even it out. with a 3.73 stock ratio, stock tires are usually 31-32" so you shouldn't be complaining too hard. Last edited by bullheimer; 07-07-2011 at 04:46 PM. |
| Looking for suggestions on gear ratio & tire size | olds73 | Hotrodding Basics | 1 | 05-18-2011 12:27 PM |
| rear ratio & tire size | yragat | Transmission - Rearend | 18 | 12-20-2007 06:45 PM |
| tire size and gear ratio | inquiring_mind2 | Transmission - Rearend | 12 | 08-17-2005 09:57 AM |
| Judging gear ratio with tire size? | gpeak | Hotrodding Basics | 2 | 06-27-2004 11:27 PM |
