-   -   I need Intake End gaskets - FELPRO!!!! (http://www.hotrodders.com/forum/i-need-intake-end-gaskets-felpro-146300.html)
Tomard 10-08-2008 11:50 AM
I keep seeing that my colleague enthusiasts generally don't like to use the end gaskets on their intakes. I happen to like the FELPRO stickon end pieces and they have worked well for me.
My problem is that I have two sets of intake gaskets AND no end pieces left :( and you can't get them without buying the whole set :evil: ---- so if any of you silicone/RTV guys have any of those, I would be happy to take them off your hands, for a few dollars of course ;)
Just email or pm me and get them out of your parts box :thumbup:
speedydeedy 10-08-2008 12:24 PM
What engine?
Tomard 10-08-2008 01:12 PM
I guess that is relevant :) SBC 350
carsavvycook 10-08-2008 02:53 PM
i refuse to rummage through the trash.
If I was 'building' one, that was going to be "Auctioned" off, through "Barret's per say, It would have to have the "factory" gaskets. If it leaks, who cares, I don't.
Use a 1/4" bead of Permatex Ultra Black silicone, on the front and rear, of the intake manifold end areas. 'Dabbing' it into the corners that meet the cylinder head.
I like to use "gaskacinch" for the rest of the intake.
Rant over :D
Tomard 10-08-2008 03:04 PM
I will probably have to end up doing that, but since I had good fortune with it, and MANY seem to not want to use them, I thought I'd ask .... :rolleyes:
malc 10-08-2008 03:20 PM
I always clean the surfaces thoroughly before applying the silicone.
Let it sit for five minutes before laying the intake on it.
GMC boogie 10-08-2008 04:16 PM
Same here. Laquer thinner works great!
S10 Racer 10-08-2008 04:22 PM
I prefer to use the gaskets. Why would you "not" use them and use silicone in place of the gaskets?
GMC boogie 10-08-2008 05:08 PM
Because(in my opinion) it works better.
Most of the manufactures must think so also as they package a small tube of RTV instead of the gaskets.
steve t 10-08-2008 05:13 PM
the gasket will slip out of place if not carefull,
boatbob2 10-08-2008 05:16 PM
end gaskets...for sbc
Hi,if using the actual end gaskets,i used to take a center punch and put punch marks about every 1/4 inch,now,i use the black permatex.no problems.
speedydeedy 10-08-2008 06:37 PM
GM stopped using the gaskets so I don't use them either. I have a brand new set from MR GASKET ultra seal part # 5820.I won't be using the ends.If you want them you can have them.They are the type with the lip that hangs over on both sides not the ones with the pins that fit in the holes.Let me know if you want them and I will mail them to you.
sam-missle 10-08-2008 07:01 PM
send me your address, and i will send you all you need. i never throw anything away.
sam-missle
Tomard 10-08-2008 07:52 PM
FELPRO ends - Not the rubber ones!
The felpro ends are made of cork, but have sticky underside to them, that you have to peel off protective layer before you stick it onto front/back of block ...
I have used it 2-3 times now, and never had a slip or leak yet ..... so until I do, I am "sticking" to it!
carsavvycook 10-08-2008 08:26 PM
You asked, we answered. Do it your way.
