I need Intake End gaskets - FELPRO!!!! - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-08-2008, 11:50 AM
I keep seeing that my colleague enthusiasts generally don't like to use the end gaskets on their intakes. I happen to like the FELPRO stickon end pieces and they have worked well for me.
My problem is that I have two sets of intake gaskets AND no end pieces left and you can't get them without buying the whole set ---- so if any of you silicone/RTV guys have any of those, I would be happy to take them off your hands, for a few dollars of course
Just email or pm me and get them out of your parts box
Old 10-08-2008, 12:24 PM
31 five window
Last journal entry: grill and rear end
What engine?
Old 10-08-2008, 01:12 PM
I guess that is relevant SBC 350
Old 10-08-2008, 02:53 PM
carsavvycook's Avatar
My 2 cents worth
Wiki Edits: 3
i refuse to rummage through the trash.
If I was 'building' one, that was going to be "Auctioned" off, through "Barret's per say, It would have to have the "factory" gaskets. If it leaks, who cares, I don't.
Use a 1/4" bead of Permatex Ultra Black silicone, on the front and rear, of the intake manifold end areas. 'Dabbing' it into the corners that meet the cylinder head.
I like to use "gaskacinch" for the rest of the intake.
Rant over
Old 10-08-2008, 03:04 PM
I will probably have to end up doing that, but since I had good fortune with it, and MANY seem to not want to use them, I thought I'd ask ....
Old 10-08-2008, 03:20 PM
malc's Avatar
Living At The Speed Of Life
I always clean the surfaces thoroughly before applying the silicone.
Let it sit for five minutes before laying the intake on it.
Old 10-08-2008, 04:16 PM
GMC boogie's Avatar
Same here. Laquer thinner works great!
Old 10-08-2008, 04:22 PM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
I prefer to use the gaskets. Why would you "not" use them and use silicone in place of the gaskets?
Old 10-08-2008, 05:08 PM
GMC boogie's Avatar
Because(in my opinion) it works better.
Most of the manufactures must think so also as they package a small tube of RTV instead of the gaskets.
Old 10-08-2008, 05:13 PM
steve t's Avatar
ex biker, now hotrodder
the gasket will slip out of place if not carefull,
Old 10-08-2008, 05:16 PM
boatbob2
end gaskets...for sbc
Hi,if using the actual end gaskets,i used to take a center punch and put punch marks about every 1/4 inch,now,i use the black permatex.no problems.
Old 10-08-2008, 06:37 PM
31 five window
GM stopped using the gaskets so I don't use them either. I have a brand new set from MR GASKET ultra seal part # 5820.I won't be using the ends.If you want them you can have them.They are the type with the lip that hangs over on both sides not the ones with the pins that fit in the holes.Let me know if you want them and I will mail them to you.
Old 10-08-2008, 07:01 PM
send me your address, and i will send you all you need. i never throw anything away.
sam-missle
Old 10-08-2008, 07:52 PM
FELPRO ends - Not the rubber ones!
The felpro ends are made of cork, but have sticky underside to them, that you have to peel off protective layer before you stick it onto front/back of block ...
I have used it 2-3 times now, and never had a slip or leak yet ..... so until I do, I am "sticking" to it!
Old 10-08-2008, 08:26 PM
My 2 cents worth
Wiki Edits: 3
You asked, we answered. Do it your way.
Rear end swap required & I'm cunfussed datsun dale Transmission - Rearend 8 12-17-2008 09:03 AM
SBC with no PCV pcoghlan Engine 18 05-25-2006 08:29 AM
Question about .015 head gaskets - FelPro 1094 surfshark Engine 2 03-30-2006 04:08 PM
silicone on intake gaskets Custom95Z Engine 24 08-01-2003 10:14 AM
Rear end swap problems datsun dale Transmission - Rearend 1 12-17-2002 10:50 PM
