I need more time, rust delay/preventative if not ready for paint? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-08-2009, 07:29 AM
I'm cleaning up the inside of my cab during a rewire and see a lot of surface rust and some points of penetration (along with plenty of hackjob body work from previous owners). I'm nowhere near ready to do a full sandblasting, bodywork, and paint on this thing but thought I might be able to take a sander to it, get rid of the surface rust and then put some sealer on it to prevent it from becoming a block of swiss cheese over the next few years until I have a place and time to take it down to the frame. I've heard POR-15 thrown around whenever rust is a concern but is this really what I should be looking to use to contain the current rust and prevent additional cancer?
Thanks!
Alden
Old 11-08-2009, 09:04 AM
boatbob2
Por 15......
Hi,i have had problems with por-15,i would sand areas with 80 grit to get rid of the rust,then 2 or 3 coats of a 2 K epoxy primer. my 48 ford coupe has neen primered with dupont DP 90 for 4over 4 years,NO SURFACE RUST.
Old 11-08-2009, 09:09 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Most of us use epoxy primer as when you get ready for paint you can just sand it to get some tooth and paint over it..yeah if you are not done done nor have the facilities of Foose it can be a pain..maybe you can just work an area and then spot prime or like we did on one a guys 38 Olds we went ahead and blasted it an put it in epoxy primer..He is a happy camper as he now has been working on the metal work for about 3 years now and has not been concerned about the re-rust deal..he just primes the completed metal patches and then carries on to the next spot..
Sam
Old 11-08-2009, 05:40 PM
deadbodyman's Avatar
Wiki Edits: 11
Google Ospho ....Ive been using it for years,sand blasting is messy and if your wiring the car you really dont want that kind of mess ,especially if the drive train is in it.use a 3-4" wire cup on an angle grinder watch it disappear it drys as a primer that protects bare metal until your ready to prime.just read the directions.I'd rather chemical strip than blast any day.then ospho and prime when ever your ready.Por 15 and all those other rust cures dont work,this does.$15.00 a qt enough for 3-4 cars...
Old 11-08-2009, 06:28 PM
mitmaks's Avatar
Last journal entry: Grille
You shouldn't have problems applying por15 over it. Waiting for it to dry appropriate amount of time and then apply epoxy primer for UV protection if it's exposed. I have coated entire trunk floor in my Charger 6+ years ago and it's nice as the day I've done it still, I can put up some pictures if you don't believe. Most of the time when someone says it doesn't work usually didn't follow procedures to the spec.
Old 11-09-2009, 06:07 AM
Wiki Edits: 11
Heres the problem I had with por-15 after I wire wheeled it and cleaned up the rust,I used it and thought it worked well too but after a few years it came back with a vengance, everything ruined...You have to stop the rusting process, simply spraying something over it just covers it up and traps it until it breaks through.now in about 5 seconds someones gonna say Ospho doesnt work ether and I'll have to say the same thing but I've been using it for 25 yrs out of the 35 I've been restoring cars and its proved itself over and over again ...So ...I guess I'm just saying that Por-15 works AND it dont.six years isnt very long ,it takes longer than that to build a car for a lot of people that do it on the side.The nice thing about Ospho is it doesnt matter how you strip the car this will keep it from rusting until your ready to prime,inside or outside and its for clean metal or rusted metal...You wouldnt put Por-15 on a car that was striped would you? Everybody uses epoxy primer...Ospho etch's bare metal and preps for epoxy as well as it disolves rust.This is what I do for a living and I swear by it,so take it for what its worth.
Old 11-09-2009, 02:37 PM
thanks for the feedback guys. I'm sure I'll be back with some more questions as I go through this thing.
Old 11-09-2009, 02:46 PM
Jon's Avatar
Jon Jon is offline
Hotrodders.com Administrator
Wiki Edits: 7314
Also, the following wiki articles may be helpful to you:
Rust
Epoxy primer
Rust encapsulators
Old 11-10-2009, 05:15 AM
Wiki Edits: 11
Check out "riot racing's" project journal he's got a rusty car hes fixing up.Anybody that has rust should give it a look....
RUST..What are the acceptable permanent ways to get rid of it? Rocket1 Body - Exterior 213 10-30-2011 06:23 AM
secrets of surface rust removal revealed Randy Ferguson Body - Exterior 178 09-24-2011 09:36 AM
65 f100 and the battle of rust. z chrome rust defender? 65fordguy Body - Exterior 3 08-03-2008 04:16 PM
Phosphoric Acid + Prevention of flash/surface rust unstable Body - Exterior 3 07-21-2003 07:36 PM
Saltwater eats Metal... What eats Rust ? Dave ESPI General Rodding Tech 10 07-09-2003 11:08 PM
