i need a piston ring part number. 98 350 vortec - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-02-2006, 07:47 PM
406 ss monte's Avatar
eat a beaver, save a tree
i can't find a part number for a set of ring to fit a std bore 98 350 vortec engine. it has the small oil rings (if it helps). about what will they cost? thanks
Old 06-03-2006, 02:38 AM
DoubleVision's Avatar
I`m not much help on part numbers, but you can get them through advance auto parts or the like. They`re not cheap, Lowest set I found was $76.99.
I was looking at getting them when I built my Vortec, but decided I`d just use KB pistons since I couldn`t get any quench out of the factory dish pistons.
Old 06-03-2006, 06:48 PM
BOBCRMAN@aol.com's Avatar
Part no.s will vary from each vendor.. These pistons take shallow millimeter rings and they are pricey.. Good ones retail for $90.00 +. A lot of guys see the price and just buy a set of new std. replacement pistons for a 350 with the old rings 5/64", for about the same money. BUT, this is not good as the replacement pistons are usually WAY heavier than the OEM rattlers!!!!!
Old 06-03-2006, 10:22 PM
NorthStar's Avatar
Sealed Power # E-921K
I could probably come up with a GM number on Monday but by then Ill have forgot.
350 TBI to 350 TBI VORTEC SWAP IWANTMOREHP Engine 8 10-20-2016 09:57 AM
Port or Full time vacuum cool rockin daddy Engine 129 10-05-2010 03:00 PM
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
what is the clearance height on a 350 piston denny1977 Engine 2 01-23-2006 10:14 PM
Cam Help black66 Engine 3 05-12-2003 06:15 PM
