I Need a Shock - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-25-2005, 06:36 PM
[NFBS]Flash's Avatar
Race @ needforbetterspeed.net
I Need a Shock
I'd like to replace this worn out shock on my 32 with a shock just like it (that is, with a cover over the top). I'm not finding anything available like this (tried P & J, Speedway, FatMan, etc.). Does anyone know where I might be able to find one similar to it?
This one is stamped as "Maeco" but I can't find any company like that.
Old 08-25-2005, 08:55 PM
30desoto's Avatar
Dodge ain't all bad
[NFBS]Flash
They look real close to the ones I have for my rearend setup and I got mine from Posie's they have an on line web page with numbers to call them.
Good Luck
30dee
Old 08-26-2005, 05:50 PM
Thanks
Thanks, 30desoto, I'm ordering a catelog from Posie's now.
Old 08-26-2005, 09:11 PM
30desoto's Avatar
Dodge ain't all bad
Flash
Hope they have what you need, looks are real close.
30dee
Old 08-26-2005, 09:16 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Have you tried So-Cal Speed Shops? I am pretty sure that they have them. You could also try The Deuce Factory.
Old 08-27-2005, 09:25 AM
Thanks Henry
Thanks, Henry. The one pictured at so-cal looks like the right one...I think it's a P & J shock...I'm requesting info now.
Thanks again.
Rear Shock Placement, Angles ZipZ28 Suspension - Brakes - Steering 22 10-08-2005 02:52 PM
Shock compression at installation? Arcuden Suspension - Brakes - Steering 3 08-24-2005 05:30 AM
53 Suburban Shock placement Sly's 53 Suburban Suspension - Brakes - Steering 2 07-03-2005 09:58 PM
Optimum rear shock angle jpd37 Suspension - Brakes - Steering 42 05-24-2005 05:55 PM
Lever Shock is in the way! rwruther Suspension - Brakes - Steering 0 06-11-2004 03:20 PM
