Hmmm, it has a self tightening serpentine belt on it, so I do not understand what you mean, I guess..........pg |
And since you did find the receipt and can verify the builder, I see no problem listing his company name for future searches on him. From what i've seen from your engine, it's a dirtbag company, www.fivestarengines.com here is his BBB sheet. Mark Last edited by Jmark; 07-15-2008 at 08:05 AM. |
I did some more looking myself this AM and found some complaints on Ripoff Report regarding Five Star Engines. I filed a report myself and told it as it is. I cannot blame Five Star since I have 3 years and 15K miles on the engine, but at the same time the engine should last what, 100,000 miles if built properly? I bought my engine from Chris and he always gave me excellent customer service every time I called him, which was a number of times. So, in all fairness, please tell him that along with the photos of the junk they sold me. In 2005 I got an email from a stranger who had bought a Five Star 350. His question was....'Have I had any problem with my engine?' He told me that he and a number of others have engines with serious problems from Five Star. My reply was that at the time I only had 5K miles on it and had no problem. But, as you may imagine, I did not sleep well for the next few nights until thought of the email was forgotten (somewhat anyways) I would appreciate hearing how the visit went after you get by there......pg |
It almost looks like something went wrong in their cleaning process that left crap in the oil galleys. The was everything is worn is very strange. Almost looks like something abrasive was floating arround in the engine. I wounder if there cleaning tank somehow got poluted.
That engine looks more like a 200K engine than a 15K engine |
This one has me really puzzled. I finally got a lead from the husband of a friend of my wife's. He owns and drives a Chevy oval track car and he gave me the name of the automotive machine shop that builds his engines. I called the shop this morning and described the mess. He said I may want to consider a short block rather than put money into the machine work. He would line bore everything, turn the crank and then I would put it all together. He said the cost is going to perhaps be the same as a short block. Maybe, but with a short block I may be right where I am today in a couple of years, since I do not know who built it. This 1992 van is only the 4th car or truck I have owned since 1965. So that tells you I run them quite a long time. I will take the block and parts to the machine shop tomorrow and see what he says after looking it over..........pg |
.010 is telling you it's a turned undersize crank. What is the surface quality, at 15000 miles it should be smooth if not polished. The journal needs to be consistently circular from end to end as well. I'd expect roughness since it's been eating the bearing and that stuff has been circulating. Telling what is bad machining from damage done by the bearing will be hard to tell apart at this point. What do the mains look like? What is the condition of the thrust bearing? And what is the crank's fore and aft clearance on the thrust bearing? Operation can lead to excessive bearing wear, what I see here is also typical of an engine operating under high loading at low RPMs. The problem that lugging causes is that the load in the bearing is high and the oil flow low. A solution is gearing up so the engine spins faster making more oil flow or installing a high volume pump to get the pressure/flow up at lower RPMs. This talk about 10psi per 1000 RPM is gross generalization more suitable for grocery getters than vehicles that work for a living. This is not an issue of type of oil (synthetic versus mineral) nor to some extent even the weight. It's an issue of putting enough oil thru the bearing to both support the development of the hydrodynamic wedge that floats the bearing above the journal with enough strength that forces on the rods aren't greater which just blows the oil out the clearance, the other is enough oil flow to take the heat out of the bearing and journal. In the latter case the greater the forces in the bearing/journal the higher the local heat being generated. Good oil flow is necessary to take this heat out. Bogie |
I just called a competator that is in the same area, a machine shop i've used before. I asked him "what do you think about Five Sta* *******", that was as far as I got before he broke into un-controllable laughter! I guess that about says it for me. He'd like to see the pictures too. Guess I can hit 2 shops in one trip!
wow I am eager to hear what the guy says after u go by there, should be interesting.
The lobes look good too, although I am far from an expert. They show some signs of wear.....like I cannot say this is a new cam because you see wear or tracks on the lobes. There is one lifter that I could not get out however until I removed the cam. This is also from my old friend cylinder #5. The bottom of the lifter is concave. Very concave. All the rest of the lifters came out easily and are dead flat across their bottoms. I don't know if the concave will show, but I will take a photo of it and stick to this post..... (It shows) The bad lifter base is really fished tailed out. The spread is so great that it would not come out of the block topside. The edge is sharp like a razor. The other lifters by comparasion, have a nice smooth beveled edge to them....pg |
| Cadillac 390 to Chevy 350 Engine Conversion | 62cadillac | Engine | 18 | 08-16-2012 03:49 AM |
| SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine | Oldsmolac911 | Hotrodders' Lounge | 50 | 01-12-2011 10:00 PM |
| engine timing- 350 chevy | stinky jinx | Engine | 7 | 06-02-2004 11:00 AM |
| 350 chevy engine buildup | dran04u | Engine | 9 | 06-07-2003 06:39 PM |
| 350 chevy engine | we2nutsinahouse | Engine | 3 | 06-15-2002 06:45 PM |
