We're winning the case!
Hotrodders Bulletin Board > Tech Help > Engine
  #76
Old 07-16-2008, 02:30 PM
piniongear piniongear is offline
Originally Posted by machine shop tom
It's also very important to use a magnetic drain plug 'cause that will give the first warning of cam or other ferrous-based metal damage.
I do not recommend plugging the by-pass on stock, daily-driven vehicles that are used in cold weather.
If the original poster would cut open his oil filter and run a magnet through the pleats, he may gain some insight as to what went through the engine.
tom
Being the original poster I can say;
(1) I have the magnetic drain plug and have never seen any metal attached to it.
(2) This is a vehicle driven almost daily, but not in cold weather for the most part. But I would never plug the bypass on my engine.
(3) Again, the Pennzoil 30-5W oil and Fram filter get changed every 3000 miles. I cannot do more than that.........pg
Old 07-16-2008, 02:36 PM
machine shop tom machine shop tom is offline
What kind of oil did was the cam broken in with, what procedure was used, and did you know that Fram oil filters have a very bad track record?
tom
Old 07-16-2008, 03:06 PM
tom
When I first put the engine in three years ago I used 5w-30 Valvaline oil and mixed 1 quart of GM Engine Oil Supplement (p/n 1051396) to the oil pan.
Then I used a drill to rotate the oil pump for 2 minutes and had a pump pressure reading of 55 psi from the Melling High Output pump.
After that I installed the distributor and started the engine.
I ran 250 miles with this mix in the pan. The I drained it, replaced the filter with a new Fram, and drove it another 1000 miles.
At that point I drained the oil again and new filter. After that the oil and filter was changed every 3000 miles.
Yes, I have heard the Fram oil filter stories, but... a history lesson:
I bought a new El Camino in 1965 and ran it for 242,000 miles.
My next car was a 1973 Chevy pick up that I ran for 117,000 when the harmonic balancer came loose and damaged the crank.
Third car was a new 1979 Chevy van. I ran that one for 188,000 miles.
Fourth was the one I have now, the 1992 Chevy van with 200,000 miles on the speedo. 15,000 of those miles was done with this POC engine.
That total is 4 vehicles in 43 years with a collective total of 747,000 miles and Fram oil filters were used 100% of the time. Never had a bad one.
Sorry, but I choose to believe my first hand experience over some fable of Fram being a bad product. You would have to prove it to me first.
I just got an engine that some greaseball threw together. What amazes me is this guy is still in business after 18 years............pg
Old 07-16-2008, 03:29 PM
oldbogie oldbogie is offline
Ahh, 5W-30, I'd stay away from that stuff. It just doesn't offer enough protection for hard working engines, those that tend to find life is low on RPMs and high on loading.
Now a series of "experts" are gonna come outa the wood work when I say what I'm gonna say; but that watered down oil just isn't good enough except in little ole lady driven vehicles. A lot of folks will jump on "watered down" and go on about the oil is rated at a 5 weight at some large sub zero degrees and a 30 weight at 212 degrees so that nothing really changes. Yet, I have never put that stuff into an engine that it didn't show a loss of oil pressure, primarily at low RPMs where I've always felt that GM engines were marginal to start with. My long standing concern has been engines that pull hard at low revs just don't have adequate protection in the crank bearings for the loads they're seeing. The problem is not so apparent at high RPMs, even in racing engine because by then the pump's delivering a lot of oil and pressure is up on the bypass valve. But when you're expecting the engine to grunt against a 6000-8000 pound load at 2000-3000 RPM there just isn't enough oil pumping thru the bearings to hold a good hydro-dynamic wedge and cool the interface. You will note that your bearings show the heaviest wear in the zone of heaviest loads right where I'd expect high loading to blow the oil wedge out. High load occurs twice a stroke; coming down under the power stroke to BDC and going over the top at the end exhaust stoke where it wants to keep going out the top of the engine as there's noting to buffer its acceleration so as the crank comes over TDC the rod get one heck of a jerk in the opposite direction to where the piston is flying toward.
Now a previous entry I speculated as to whether the failed cam and lifter may have put in the gunk that caused a situation where the rod bearings failed, or whether the failed rod bearings put in enough gunk to fail the cam lobe and lifter. I also stated that either could be related to neither. This seems to have set off a great exploration of filter mania. All that aside, the relationship between these failures is probably the 5W-30, again, this stuff doesn't have the Extreme Pressure (EP) element is sufficient quantity to protect a sliding tappet lifter and cam, this situation is compounded by low RPMS because it extends the time of loaded contact. This is a situation where the maximum load is present for a long duration of time, permitting the lubricant time to escape from the applied load and also generating a lot of local heat. In this situation the weak link will give up. Lots of people think that high loads and heat come with excessive RPMs, this isn't a singular truth. These are also common to situations where the speeds are too slow for the applied loads. The specific cause of the failure will be somewhat different, but the result will look a lot the same when you pick thru the wreckage.
The apparent lack of ferrous material collecting on your pan bolt magnet shows the filter was doing its job and the amount of material accumulated in 3000 miles was so small as to go un-noticed by your visual inspection. The failed bearing material would not be magnetic thus would not show on the magnet till the copper was worn thru to the steel backing. The bearing material would have been well mixed with the oil, if the filter didn't get it first, to where it would be hard to see, especially if you didn't know what to look for which would have been faint metallic streaks in the drain oil.
The only thing I'll recommend, is that you don't use any of that 5W-XX swill in your next engine, save it for grandma's Sunday goin' to church Buick. I can't tell you the number of engines all the manufacturer's have had to warranty with that stuff in 'em. It's there to get their "Corporate Average Fuel Mileage", as tested to government rules, up as high as possible, no other reason than that to reduce the power used for internal pumping losses. This is passable for motors that don't work too hard. If you expect them to do work in the day to day world with these mini weight oils in them, you've got to expect some bearing failures and certainly if you're running a flat tappet can some lobes and lifters are going to eat it. Fill the crankcase with a good 15W-40 or 20W-50 and save the bearings, lobes and lifters and forget the sellers and recommenders of "skim" oil.
Bogie
Old 07-16-2008, 03:55 PM
Bogie
As I have said in previous posts, my engine has a Melling High Output oil pump.It sits there idling and the gauge reads 55 psi. I call that high enough.
The engine is in a van, not a dump truck or wrecker.
Most of the driving is at 75 mph out on the highway, so while that is not a lot of rpm, it is enough to get me a ticket if I'm not careful.
I have used 5-30 since the day it came out. As I said in an earlier post my driving time is 43 years with 4 different Chevrolets covering 747,000 miles.
I use either Valvoline or Pennzoil and a Fram filter and nothing will change my mind on that........pg
Old 07-16-2008, 07:49 PM
I have had 3 first-hand and 3 second-hand (personally knew the guys with the problems) with Fram filters.
The pictures of your lifter bottoms is consistent with improper cam break-in oil, pre-lube, procedures, or a combination of those.
The lines in the less damaged bearings came from very small foreign material circulating through the engine. The more damaged bearings exhibit symptoms of bearing distress caused by particle damage that compromised the bearings' load carrying cababilty.
The fine scratches in the cylinder(s) came from material from the cam lobe and lifters.
That HV pump is doing nothing to help you.
I will take my 30+ years in engine repair and 25+ years in machine shop experience and leave you to your extensive background.
tom
Old 07-16-2008, 10:58 PM
CNC BLOCKS NE CNC BLOCKS NE is offline
CNC Blocks Northeast
I really doubt that the 5-30 is really considered a flat tappet oil as I can see why you had all that damage to your engine with the oil and filters you are using and the oil today is a lot different then 43 years ago.
You may want to listen to some of us guys who build engines for a living and have some pretty good advice to follow.
The problems your having we don't seem to have so I would say your doing something wrong.
Old 07-16-2008, 11:20 PM
carsavvycook's Avatar
carsavvycook carsavvycook is offline
My 2 cents worth
carsavvycook's barnstar
Wiki editor
Wiki Edits: 3
This would differ, on how complete the engine came to him. If it came "fully dressed" oil pan to intake manifold, He has a complaint. If not, I don't think he would have started this thread. JMO
Old 07-17-2008, 01:42 AM
techron techron is offline
hi guys , i haven't posted in a while because i have been going hot and heavy on the chassis, suspension, drivleline, plumbing and mods on my C2-GS clone. just about finished with that and getting ready to start on the body.
piniongear, welcome to hotrodders. here's my take, (and i had no intentions of posting tonight):
as always, i totally agree with oldbogie.
what i see in your excellent pics in this thread is supreme shoddy workmanship.
1-from the main bearing pics it looks like you have a bent/warped crank
2-from the rod bearing pics it looks like you have bent rods or a disasterously machined crank
3-adding weld to the crank holes to balance is just wrong.
4-the engine seems to have been assembled with a bunch of machining debris left inside
5-the lifters in the pics are toast, and therefore the cam is toast.
6-think about where all that metal from all those worn parts is hiding in your engine.
7-think about all the wear on the parts you didn't inspect yet from all the metal circulating through the engine.
8-CNC NE + MST know their stuff, so if they don't agree, i will bow to their superior machine shop knoledge.
i hate to be the bearer of bad news, but toss that engine in the nearest trash can and buy another 350, they are cheap enough, you will be many $$$$ ahead and you will save yourself many future headaches.
i have thrown away many trashed engines in my time, sometimes it's just better and cheaper to start over...
EDIT: and i would never ever use 5W-30 in any engine, i have always used 20W-50 and have recently switched brands for the higher ZDDP content...
Old 07-17-2008, 07:59 AM
eldoradoboy eldoradoboy is offline
I would say that even a good filter will miss quite a bit of smaller particles.. and that van is heavy enough that it is working the engine at low RPMS to get it up to speed.. and I'll bet its not taching very high out on the road either....
ive come to the conclusion that I got a CRAP engine for my monte carlo.. its coming out to go to a machine shop for teardown as I dont have the extensive knowledge to tell where my excessive valve train noise comes from..
but I do know that when I drained the oil pan I could see what looks like very slight metallic swirls in the oil so I know there is serious mechanical damage going on...
Also oil PRESSURE isnt everything.. im gonna venture to say that the dash gauge Port on this engine is right back by the oil filter.. so what you are getting is a pressure reading right off the oil pump.. all that says is that the pressure at that point is proper.. doesnt mean you dont have an oiling problem farther along in the oil circuit... and most likely that engine being thrown together like it was probably had pretty loose tolerances.. that once the wear starts creates even looser tolerances... a HV oil pump does just that pumps a lot of oil and in doing so builds up pressure..
but think of this analogy.. if you could put a pressure gauge on your garden hose and turn on the water.. you can cover up the end of the hose with your thumb and the water will just trickle out.. but the pressure would still read high.. uncover a little more of the hose and the pressure may ver ywell stay the same but you will have more water flowing because the hose and the water source (your well pump or city water as it may be) can handle the volume you are flowing.. take your thumb off altogether and you'd see a pressure drop but have Lots of water flowing..
pressure builds up as a result of a restriction thats just a fact of physics.. so the PLAN is that the restriction in an engine that creates pressure is the bearings / lifters themselves.. but if the tolerances are too loose you would see a drop in oil pressure.. so most install a HV (high volume) pump.. and get that feel good feeling because the dash gauge reads 55 on the highway 40 at idle... thats great as long as the pressure is really the bearings.. but what if you are just pressurizing against the oil gallerys themselves.. the passages are only so big in an engine.. with these worn out bearings the tolerances wouldve gone to heck in a handbasket and oil should just Flow out.. causing a reduction in pressure.. yet the gauge pressure didnt show any drop... so i think we have a classic oil starved motor here.. shoddy work gone bad that causes a compounded issue then of oil starvation at the bearings....
so one could say the lifters should rattle.. however it doesnt take much oil pressure to pump the lifters up.. lifters will stay quiet at 5 PSI.. or perhaps the lifter gallery passages were fine and tis just the main / crank oiling that was bad..
my main point here is a couple things.
1] just because the pressure at the gauge sender is high doesnt mean we have oil everywhere..
2] I wouldve certainly thought we would see some kind of oil pressure changes with worn out bearings like these.. we have bearings that have had to add .005 - .010 or more in tolerance to the journals... thats a lot of area for oil to flow through and reduce pressure...
-Christopher
Old 07-17-2008, 08:44 AM
Eldoradoboy......
2] I would have certainly thought we would see some kind of oil pressure changes with worn out bearings like these.. we have bearings that have had to add .005 - .010 or more in tolerance to the journals... thats a lot of area for oil to flow through and reduce pressure...
-Christopher
What you say makes sense regarding the oil pressure being read at the pump.
Now we all know how worn out these bearings are. So yes, there was less restriction than when the bearings were new. (Well, maybe not in my case here ) but you are right.
I understand pressure, volume flow etc, but I think the pump was still letting all of the bearings get plenty of oil, even though the gaps were massive.
If the oil was insufficient, then I would think there would be some blue spots indicating over heating in some part of the engine, but there is none of that anywhere.
I have to lay the cause of the problem at the feet of the guy who did the build of course. What I would like to know is what this person failed to do properly when he built it?
Today I finally have everything loaded in the truck and will head to the machine shop shortly. If here is any earth shaking news from them I will post the info for you guys to kick around.........pg
Old 07-17-2008, 09:21 AM
I think all of this is a chain reaction that started either with a bad block core? maybe it needed line honed and they didnt do so..
or improper assembly.. rather than a new crank they used a turned and refitted crank... what caused the crank originally to be so bad it needed turned??
when getting a rebuilt engine something caused it to need rebuilt in the first place... could be anything... couldve just worn out from high miles.. couldve been grenaded by over rev... couldve been overheated to the point it seized.. we'll never know how they got this block in the first place....
im kind of in the same boat as my "new" engine has serious problems in it.. but hydrualic lifters dont just clatter all day long and be called "normal".. and for the same reason I dont know where my block came from either.. or why it was in an engine builder's shop... so mine, like yours is on its way to a machine shop for closer inspection....
I honestly dont think you did anything wrong to the engine... my friend ken runs 5w-30(10w-30 in summer) oil in his 1991 camaro and has since they day he bought the car new... it has a 305 in it now with 185,000 miles on it. that has to be one of the quietest, smoothest running small block chevies ive ever seen.... its so smooth you dont even hear a rhythm to that engine..... oil stick is always full at 3000 miles too..
now back to rebuilt engines.. I have often heard that some racing engine builders (drag race)will put looser tolerances on mains and rods noting they want lots of oil flow over the bearings for cooling and also noting these engines are run in short heavy duty bursts, never fully warmed up.
so does this shop normally build racing engines but seels a few "stock replacements" also?
my engine builder even told me himself that he built mine a little loose and then sold it as a "streetrod" engine.. not fully realizing the stress that street use puts on a motor.... I think he feels my engine is fine with the lifters clattering away when the engine is hot.. because if it was a drag race engine it would never be running 15 minutes at a time...
street stress is bad... I know for me my hotrod spends a lot of time idling... drive it to work.. then sit in 95 degree heat idling through traffic with the A/C blasting.. or going through a 30 minute 4th of july parade same thing... and I think a lot of engine builders fail to see the differences required to build a high performance(or stock performance) daily use street engine versus a drag strip engine..
-Christopher
Old 07-17-2008, 10:25 AM
-Christopher
I beleive your 1991 has roller lifter and not flat tappet lifter as there is a big differance between the 2 and a flat tappet engines requires better oil then 5-30
The oil we recomend has 1582 PPM of zinc and is a diesel 15/40 oil and no isses of premature cam and lifter wear.
Old 07-17-2008, 10:31 AM
yes you are right my friend's camaro does have a roller cam and Lifters in it...
and i agree on the oil... in my hotrod engines with flat tappet cams.. i used to run rotella T 15w-40 but even rotella T as of late has reduced the ZDDP in their oils...
so i run Valvoline VR-1 20w-50 and also the ZDDPlus additive to it..
my only point about my friend's camaro is that all the engine bearings have survived using 5w-30 oil because that engine is factory built with no doubt tighter clearances than most racing shops will do.. as it is built for the street.. it has a redline of 5200 RPM as opposed to the 7000 RPM that race motors typically carry...
the shop that built PG's engine may have built this engine using looser racing clearances rather than OE clearances..
-Christopher
Old 07-17-2008, 11:57 AM
74chevy454's Avatar
74chevy454 74chevy454 is offline
So when building street/strip motors where u mainly want to be a daily driver but be able to go to the strip on the weekends,which oils would u pros be using when building and running these types of motors.
I have a bbc 468 just got done and is ready for start up its got the edelbrock preformer package in it so the cam is a little lopey it was put together right was just curious what u guys would run in it, and really would like to here from everybody...
sorry
not trying to highjack a thread
Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "I need some help with my 350 Chevy engine..."
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 47 05-01-2009 11:14 AM
Cadillac 390 to Chevy 350 Engine Conversion 62cadillac Engine 17 05-11-2007 04:19 PM
engine timing- 350 chevy stinky jinx Engine 7 06-02-2004 11:00 AM
350 chevy engine buildup dran04u Engine 9 06-07-2003 06:39 PM
350 chevy engine we2nutsinahouse Engine 3 06-15-2002 06:45 PM
