Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - I need some help with my 350 Chevy engine...
Old 07-12-2008, 02:49 AM
carsavvycook's Avatar
carsavvycook carsavvycook is offline
My 2 cents worth
Wiki Edits: 3
Originally Posted by piniongear
The Lisle 36500 ridge reamer showed up today. I know it is a reamer, so I should only turn it clockwise. I assume I use a generous amount of cutting oil too? The cutter is carbide so I am not sure.
Nothing in the instructions tells me to lube it.
I am really eager to have a look at the #1 piston.......pg
With only 15K miles, you should not have to Ridge Ream that cylinder. A sharp knife should get the black carbon build-up off of the top of the cylinder wall. JMO and experience.
Pictures of that piston would be nice. The way I know how to up-load them, is to scroll down to "Manage Attachments"(while posting), and click on it. This will take you to a upload page. You need to make sure your pictures are downsized, edit in your picture manager, then simply hit "browse" and click on the picture/pictures, and click on "upload". These will show up under your "post" when you are done.
How others on here, get their pictures in their post, I have not figured out yet.
