Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - I need some help with my 350 Chevy engine...
Old 07-12-2008, 05:28 PM
piniongear piniongear is offline
Here are the shots of the piston and bore.
The piston looks really good to me. No cracks. No scuffing, and the skirt walls look like I just took the piston out of the box.
The bore looks good too. Hard to take a photo of it, but the walls are smooth top to bottom. There are a couple of light lines on the wall which seem to match light lines on the piston.
Back to the crank: I forgot to mention that the journal feels a bit rough if I drag a fingernail over it. I did not get a shot of it, but it certainly is not smooth as it would be if it were freshly ground. Again, I do not know what 15K miles will do to the surface. Oil has been changed every 3K miles.
I sure hope you guys have something to tell me about this. Meanwhile, I will continue to remove rods and pistons I guess.......pg
Name:	PHOTO #4_No 1 Piston_ Skirt Facing Intake.jpg
ID:	31120   Click image for larger version
Name:	PHOTO # 5_No 1 Piston_Skirt Facing Outboard of Intake .jpg
ID:	31121   Click image for larger version
Name:	PHOTO # 6_Looking down onto Cylinder #1.JPG
