Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - I need some help with my 350 Chevy engine...
  #40 (permalink)
Old 07-14-2008, 09:25 AM
Double_v23's Avatar
Double_v23 Double_v23 is offline
Horsepower Enthusiast
Last journal entry: Finished BMOD001FH
The factory did not add weight by welding in plugs like that so I would say that your engine was balanced during the rebuild.
I would think that they set the clearances too loose. What oil pump was in the motor? Does it have a plug that you can change the pressure spring in it? What color is the spring if it is changeable?
