Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - I need some help with my 350 Chevy engine...
  #44 (permalink)
Old 07-14-2008, 07:09 PM
piniongear piniongear is offline
Back with some crank photos....
This morning I removed the camshaft and crank.
The crank bearings were worn about the same as the rod journal bearings, i.e., lots of copper showing, except for #5 at the rear. It was mostly silver colored.
Here are the 5 main journals, starting with #5 and going to #1.
I will add some more pics in the next reply......pg
Name:	#5 Block Bearing (Medium).jpg
ID:	31185   Click image for larger version
Name:	#4 Block Bearing (Medium).jpg
ID:	31186   Click image for larger version
Name:	#3 Block Bearing (Medium).jpg
ID:	31187   Click image for larger version
Name:	#2 Block Bearing (Medium).jpg
ID:	31188   Click image for larger version
Name:	#1 Block Bearing (Medium).jpg
