Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - I need some help with my 350 Chevy engine...
  #62 (permalink)
Old 07-15-2008, 06:07 PM
carsavvycook's Avatar
carsavvycook carsavvycook is offline
My 2 cents worth
Wiki Edits: 3
Every concave lifter face I have ever seen, the cam lobe it was riding on has been worn down. I suggest you take a good lifter, and put it in that bad "lifter" bore in the block, and check for a loose fit. Compare the feel to the other lifter bores in the block. I doubt it was too tight from the outside finish on it.
