Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - I need some help with my 350 Chevy engine...
  #78 (permalink)
Old 07-16-2008, 03:06 PM
piniongear piniongear is offline
Originally Posted by machine shop tom
What kind of oil did was the cam broken in with, what procedure was used, and did you know that Fram oil filters have a very bad track record?
When I first put the engine in three years ago I used 5w-30 Valvaline oil and mixed 1 quart of GM Engine Oil Supplement (p/n 1051396) to the oil pan.
Then I used a drill to rotate the oil pump for 2 minutes and had a pump pressure reading of 55 psi from the Melling High Output pump.
After that I installed the distributor and started the engine.
I ran 250 miles with this mix in the pan. The I drained it, replaced the filter with a new Fram, and drove it another 1000 miles.
At that point I drained the oil again and new filter. After that the oil and filter was changed every 3000 miles.
Yes, I have heard the Fram oil filter stories, but... a history lesson:
I bought a new El Camino in 1965 and ran it for 242,000 miles.
My next car was a 1973 Chevy pick up that I ran for 117,000 when the harmonic balancer came loose and damaged the crank.
Third car was a new 1979 Chevy van. I ran that one for 188,000 miles.
Fourth was the one I have now, the 1992 Chevy van with 200,000 miles on the speedo. 15,000 of those miles was done with this POC engine.
That total is 4 vehicles in 43 years with a collective total of 747,000 miles and Fram oil filters were used 100% of the time. Never had a bad one.
Sorry, but I choose to believe my first hand experience over some fable of Fram being a bad product. You would have to prove it to me first.
I just got an engine that some greaseball threw together. What amazes me is this guy is still in business after 18
