-   -   i need some help with tire sizes (http://www.hotrodders.com/forum/i-need-some-help-tire-sizes-43672.html)
digitalfrek 07-18-2004 04:11 PM
on my truck i currently have 235/75 r15 on it i want a taller wider tire but i dont understand the numbers, i know the 15 is rim size so what are the other 2
firechicken383 07-18-2004 05:39 PM
The 235 is the tread width, the 75 is the sidewall height. Its a ratio of the tread width. So your sidewall height is 75% of your tread width. 255/70/r15 would be taller and wider.
Tire size calculator
http://www.miata.net/garage/tirecalc.html:
:thumbup:
dmorris1200 07-18-2004 05:57 PM
235 is tire width (or Section Width), not tread width. Two totally different things.
http://hotrodders.com/photos/0000145..._121992289.gif
firechicken383 07-18-2004 06:41 PM
Yes thats what I meant, guess I was trying not to confuse him with just width. :thumbup:
5window 07-18-2004 07:28 PM
Check out the folks at Coker Tire (cokertire.com). I have found them to be very helpful . If their catalog doesn't give you conversion sizes, they will promptly answer your e-mailed questions and give you suggestions on new tire sizes.
digitalfrek 07-18-2004 08:36 PM
thanks for the help guys
Kevin45 07-19-2004 02:42 PM
This is stored in our Knowledge Base TIRE NUMBERS AND WHAT THEY MEAN
Kevin
