We're winning the case!
Hotrodders Bulletin Board > Tech Help > Body - Exterior
  #1
Old 07-18-2004, 04:11 PM
digitalfrek digitalfrek is offline
i need some help with tire sizes
on my truck i currently have 235/75 r15 on it i want a taller wider tire but i dont understand the numbers, i know the 15 is rim size so what are the other 2
Old 07-18-2004, 05:39 PM
firechicken383 firechicken383 is offline
The 235 is the tread width, the 75 is the sidewall height. Its a ratio of the tread width. So your sidewall height is 75% of your tread width. 255/70/r15 would be taller and wider.
Tire size calculator
http://www.miata.net/garage/tirecalc.html:
Old 07-18-2004, 05:57 PM
dmorris1200's Avatar
dmorris1200 dmorris1200 is offline
doesn't play well with others
235 is tire width (or Section Width), not tread width. Two totally different things.
Old 07-18-2004, 06:41 PM
Yes thats what I meant, guess I was trying not to confuse him with just width.
Old 07-18-2004, 07:28 PM
5window 5window is offline
Check out the folks at Coker Tire (cokertire.com). I have found them to be very helpful . If their catalog doesn't give you conversion sizes, they will promptly answer your e-mailed questions and give you suggestions on new tire sizes.
Old 07-18-2004, 08:36 PM
thanks for the help guys
Old 07-19-2004, 02:42 PM
Kevin45's Avatar
Kevin45 Kevin45 is offline
Just one of the guys
This is stored in our Knowledge Base TIRE NUMBERS AND WHAT THEY MEAN
Kevin
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
