i need somthing heat resistant to "bondo" over a weld on a pipe - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-31-2005, 09:42 PM
lowROLLERchevy's Avatar
... & Insanity Ensues .....
Last wiki edit: The FREE T Bucket plans Last photo:
Wiki Edits: 22
my friend Tom is turbocharging his 2000 eclipse, and im the one thats making all the charge pipes and exhaust
well my welding skills are a little rusty, and the first pipe i made has some cruddy looking welds on it that i would like to grind and fill
the problem is, its the hotpipe off the compressor (intake) side of the turbo, so its gonna wind up pretty damn warm at times , plus that charge pipe and the exhaust get to cross paths somewhat, heatsoaking that pipe even more
any suggestions on what i can use to smooth the pipe ?
doesnt have to sand out show perfect, just as long as it looks acceptable and can accept a coat of paint
Old 07-31-2005, 10:46 PM
slammed88
powder coating would be a better alternative.
Old 08-01-2005, 12:33 AM
Wiki Edits: 22
nah, the welds arent nice enough for that ... i dont have a bandsaw so my cuts arent as neat as they should be, and in a few spots i had to go back and patch a pinhole or two ... which doesnt leave a very smooth weld unless your realy good with a welder
im good enough to work in a body shop ... not good enough to be a structural welder , lol
Old 08-01-2005, 04:36 AM
jcclark's Avatar
The Penny Pincher
Last journal entry: Hanging Bumpers
What about some of that muffler patch stuff that
comes in a tube? I don't know , just something to consider.
Old 08-01-2005, 05:26 AM
Jake_Dragon's Avatar
Last journal entry: New Carb
4 1/2 inch grinder and some 80 grit sand paper.
You can clean them up pretty good with a grinder then smooth them down with the 80 grit.
Don't get to aggressive or you will just crack the pipe the first time it cools off.
I would leave the welds for strength but if you know you have good penetration then you could buff them off of the pipe and it would look like one piece.
Old 08-01-2005, 02:08 PM
rrmccabe's Avatar
GM Muscle
Is this something that gets painted?
How close to the exhaust is it? JB weld is good to 500 degrees if you are looking for something like that it will work. 500 degrees is not enough for an exhaust manifold..
So it its something that you are going to paint, you can JB weld it. It files and sands like hard bondo.
<edit> Just saw this. http://www.por15.com/product.asp?productid=7
Old 08-01-2005, 07:52 PM
Wiki Edits: 22
the pipe passes about an inch and a 1/2 away from the exhaust, and the welds are like 5 inches down the pipe
i know that i have good penetration on my welds, as i tend to weld with a bit high of a heat setting ....
after thinking about it, i think that bondo should work fine, becase baking pain booths get up around 200, and it doesnt wreck bondo, and i wouldnt expect this pipe to get any hotter then that
i have the welds ground down a good ways, but the u bends i used came from a diff company then the straight pipes, just enough to make it almost impossible to get a smooth look if i was to grind it down flush
oh well ... i have 2 more piping kits to make , this one was my practice, ill be much happier w/ kit 2 & 3im sure
thanks guys
Old 08-01-2005, 08:18 PM
antiquecar's Avatar
old car nut
Go with the JB Weld not bondo. I use JB on radiators when I need filler. Works great.
Old 08-02-2005, 05:11 AM
mrcleanr6's Avatar
dont use the bondo. i bet that pipe will get higher than 200. most engine thermostats are set at 195 plus its somewhat close to the header pipe which i'm sure is around 1000 or higher. jb would be a better choice but after you grind down the welds of you have pinholes your better off hitting them again with the welder to fill in the holes then grind down again. you might be better off asking someone that does powdercoating what they use since most of those parts are baked at around 450.
"Basic of Basics" Welding - How do I repair body panels? Centerline Body - Exterior 33 03-31-2014 09:45 AM
Exhaust Diameter Formula ChevelleSS_LS6 Engine 11 04-27-2012 09:21 PM
Welding info Kevin45 Body - Exterior 10 08-26-2011 08:09 AM
Welding Books Magnus_Jager General Rodding Tech 6 11-29-2005 03:57 PM
Airlines Kevin45 Garage - Tools 22 03-04-2004 04:35 AM
