Originally Posted by 1F9O4R7D
I got the kingpin out and the spindle off the axle but I can't get the spindle off of the steering arm. It is a ball joint connection. Does this need to be pressed out?
ALSO ... the tie rod end will screw out of the drag link. They come in right hand threads and left hand threads ... depending on which side they are installed. They are available new ... for mot much $$$. I believe I would consider replacing them ... while you are this close.
