I believe a 42 to 48 car spindle is the same ... but I could be WRONG
I would call Dick Spadaro ... he sells parts, is very knowledgeable and most of all HELPFUL. Tech Line: 518-861-5367 He is in New York state. I have a couple pair of 48 to 52 F1 spindles but I do not know if they are the same as yours. I just started messing with the newer stuff ( like late 40's ) recently. Here is my current project. ![]() It is a 1949 Mercury 1/2 ton pickup. Only available when new in Canada. .
"I won't be wronged . I won't be insulted, and I won't be laid a hand on. " |
You need a pickle fork ... a special tool made for separating the two.
Most of the chain-type parts stores ( Auto Zone/ Advance / O'Reilys ) have a tools loaner program and they have this tool in that program ( usually ) They are not that expensive to buy ( I have a old Snap-On one that I got a a yard sale 20/25 years ago for 5 dollars. If you were close ... I would let you borrow it
Not sure about that newer style king pin, but most have a locking mechanism, such as a bolt into a grove/dimple in the king pin. Remove that an it should come out relatively easy. A new king pin and bushings should be in order as well.
Trees |
I finally found some time and completed the job. just one thing odd though the new bearing/grease seal and nut will not go onto the spindle enough so I can put the cotter pin back in the axle. I am assuming the little rust that is on the new spindle is causing this. I am thinking if I drive around for a bit then try to tighten the nut, maybe the surface rust will waer off.
I am certain the new spindle is the exact one I need but the diameter of the axle is slightly enlarged by the rust. Any comments? Next project I have to adjust the drum brakes. What is the best way to do this front or back first? Thanks Kyle |
re;'47 spindle
Bonus thought,the old kingpin makes a great drift/driver. don't chuck it. the old skool way to pop it was to take 2 large hammers place one against the back of the stud hole and whack from the other side,just be sure to wear eye protection!
| 1940 Ford pickup box and door questions? | Skiman | Hotrodding Basics | 10 | 04-04-2011 05:50 PM |
| USING LATE 80'S FRAME FOR A 1937 FORD PICKUP | DIGGER | Body - Exterior | 23 | 10-07-2009 07:43 AM |
| help with 1935 ford pickup | raf | Introduce Yourself | 2 | 10-27-2005 03:30 PM |
| 47 ford rear swap (parallel leaf springs) | ONEGALONLY | Suspension - Brakes - Steering | 4 | 10-06-2005 07:06 AM |
| 40 Ford Pickup Body Parts | enemyace | Body - Exterior | 1 | 03-23-2003 10:54 PM |
