I need transmission help - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-25-2007, 01:17 PM
Ok I am about to go crazy! I rebuilt my TH350. Installed it today. When I filled the case up with fluid the trans leaks out the tailshaft ?? Is this normal unless you have the yoke in ? Will a trans leak there when the yoke is out?
TIA
Old 05-25-2007, 01:40 PM
jakeshoe's Avatar
Brian,
Yes it will leak.
The tailshaft is sealed by the yoke. There must be lube present in the rear for the output bushing.
94 Dodge Transmission Electronics problem? Native Gearhead Transmission - Rearend 7 10-17-2006 10:00 PM
Hotrodders Knowledge Base: Transmission - Rearend Jon Transmission - Rearend 0 11-26-2005 06:23 PM
transmission oil type. TVR383 Transmission - Rearend 3 06-05-2005 09:28 AM
Transmission Information. M&M CUSTOM Transmission - Rearend 1 08-24-2004 03:15 PM
83 Z28 Transmission - YIKES! crandaz28 Transmission - Rearend 4 11-25-2003 07:43 AM
