I need a valve spring - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-16-2008, 06:14 AM
I need a replacement valve spring for a 406 sbc. the inner spring broke after a few hrs of use.
the O.D. is 1.580, I.D. is .750 the free hight is 2.550 its a dual spring w/damper, color code looks white or very light grey, the installed hight looks like 1.900-2.10, hard to measure w/my red neck engineering calipers. it was set up for a soild roller cam .6688 lift using 1.6 rockers
the org. spring manufacture is unknown, I've looked on the net till my eyes R falling out, I dont want to buy a whole set just to replace 1 inner spring.
Please, if U can help, much thanks
Old 05-16-2008, 06:37 AM
If I were you, I would take no chances and REPLACE THEM ALL. There are many claiming broken COMP springs - not saying that's what you have, or that's what your problem is. Just saying that for the investment you may very well wind up saving a lot more money in the long run. Have you checked all of your springs pressures???
Old 05-16-2008, 08:56 AM
I guess I'll swap out the springs...whats the correct springs for the motor?
263/273 dur @ .50 .627 lift, install hight anywherer from 1.900-2.100
13.8 c/r w/tunnelram, my push rods are 8.100, had 1.6 Lunati rocker on it B4, I have a set of 1.5 CopCams I'm going too,
crane told me the inner spring broke due to using the motor to long in the 2500 rpm range, that this motor is a race only, and the harmonics at low rpms prob. broke the inner spring???
so go to a lower seat pressure and drop my redline to 6K max.
I have a Rev kit, so the solid roller stick and lifters should B ok!
I have a set of teflon oil seals so the inner spring cant B too small.
my inner now measures .753 I.D.
I'm not gonna race the boat, may B wack it every now and then, mostly around 5-6000 max. and 2500-3500 just screw balling around.
Old 05-16-2008, 09:28 AM
Banned
um... with that setup a 6K redline won't even see your max power potential... If you wanted to keep it under 6K having a more mild build would have netted you MORE power... It really is a nice setup, i just think you're never going to see its full potential.
Old 05-16-2008, 10:08 AM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Go to the cam manufacturer, they have all the data and spring requirements, you can't simply pull springs off the shelf, your cam profile/ramp aggressiveness and lift have a lot to do with spring requirements.
Semper Fi
Old 05-17-2008, 01:50 AM
#9995's that'll do it,
as far as the spring breaking cuz it was hanging out too long around 2500R's
Isky kinda Laffed at that, ,more likely do to the long stowage, 7yrs!
Boat= B.O.A.T. break out another thousand
Valve Spring Pressures for Roller Cam - BBC - Help leejoy Engine 7 03-23-2008 05:12 PM
Valve Spring Compressor Tool Question leejoy Engine 9 02-27-2008 11:57 AM
SBC Valve Spring Setup malc Engine 16 11-10-2006 01:06 PM
Compressed Valve Spring Fatigue Garbonzo Bojangles Engine 8 01-25-2006 06:44 PM
valve spring diameters matt_ramsey Engine 2 03-07-2005 02:01 PM
