I need your feedback Specs for my new 383 stroker - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-13-2004, 10:29 PM
New Member
Unhappy I need your feedback Specs for my new 383 stroker
1990 GMC 350
Made into a 383 stroker: factory two bolt main/Standard bore/hot tanked&honed /clearanced for crank&rods/new cam bearings
HEADS Factory swirl port truck heads 1.94 intake 1.50 exhust
valve job & seals hot tanked
CRANK Scat cast externally balanced stroker 383 one piece real seal
RODS Factory forged 5.7 inch long press fit clearanced for cam
PISTONS Speed pro 383 flat top two valve reliefs coated skirts press fit standard size
CAM Competition cs 268 h 10 high energy hydraulic flat tappet
TIMING CHAIN Double row roller by zoom
LIFTERS Sealed power flat tappet hydraulic
Bearings michigan 77 rod & mains
RINGS Hastings moly plasma
OIL PUMP Melling high volume pressure (MV_55)
INTAKE aluminum stock trottle body injection (tbi)
IGNITION Stock computer controlled new cap rotor and plugs
EXHAUST Hooker competition headers with dule exhaust (no cats)
flowmaster
WATER PUMP stock
THERMOSTAT 195
INDUCTION stock TBI & air hog high flow filter
here r some pic of it
TELL ME WHAT YOU THINK I NEED YOUR FEERBACK!!!!!!
Old 12-13-2004, 10:30 PM
killerformula's Avatar
Last wiki edit: Carburetor
Last journal entry: Clean up
Wiki Edits: 3
sounds like a good mild build. Ditch the high volume oil pump, all it does is robs horsepower.
K
Old 12-13-2004, 10:53 PM
New Member
COULD I go to a better intake and throttle body for more horsepower . I HAVE ABOUT $700.00 left could I do it should i do it . If so please let me know the right one to get please.
Old 12-13-2004, 11:06 PM
Wiki Edits: 3
WHY ARE YOU RUNNING A FLAT TAPPET CAM IN A ROLLER BLOCK!?!?!!?
Good god man, get a roller cam!
K
Old 12-13-2004, 11:15 PM
New Member
I think a flat tappet cam is what came out of it i think.
Old 12-13-2004, 11:36 PM
firestone's Avatar
http://teamrfc.gospelcom.net
Have you already bought the parts? If so, then I agree that a roller cam would be a good idea. If you have not already bought the parts, I have some other ideas. another idea is gears and posi if you dont already have them.
Adam
Old 12-13-2004, 11:42 PM
New Member
Yes the parts are in the truck and it is running. I have 456 gears and a locker
Old 12-14-2004, 10:22 AM
Siggy_Freud's Avatar
Being that its a 90 block it should have provisions for a roller cam (without having to retrofit). If this is the case, go with a roller cam. They are more expensive and require more expensive lifters, but the technology is way ahead of the flat tappet design. Less cam wear, no cam breakin worries compared to a flat tappet design, and I believe they allow higher lift due to their design and the design of the lifters.
Bringing history and technology together.
Old 12-14-2004, 11:29 AM
johnsongrass1's Avatar
Race it, Don't rice it!
With a torque making 383 and 456's you could get away with a cam in the 292 range to make more upper rpm power and not lose a signifigant amount of low end
Old 01-10-2006, 07:24 PM
High volume oil pump..
Definetly get rid of the high vol pump..Will suck the pan dry and potentially burn up your engine..
Old 01-10-2006, 09:37 PM
NAIRB's Avatar
Not a bad setup for a TBI engine. I would have ditched the TBI heads for something else, but since you've already got them, they'll work okay.
Not all of the FI blocks are roller cam blocks. Some have the provision, and some don't.
Anyway, with the stock TBI system, you aren't gonna make much over 300 ponies anyway.
Old 01-11-2006, 09:39 AM
That cam with those heads on a TBI system will not run very well at all. I doubt the stock TBI system will supply enough fuel for that cam and those heads will choke the cam down.
compcam 268
Gross Valve Lift 0.479 0.48
Duration At 0.006 Tappet Lift 268 280
Lobe Separation 114
Old 01-11-2006, 10:12 AM
NXS's Avatar
NXS NXS is offline
wind & fire = guides to power
This thread is so old he may have rebuilt that engine twice by now
