Four lenght's of 3/8x16 all thread cut into studs, or just real studs, will make lining things up a lot easier since you are limited on a tranny jack.
Cut a slot into each one so you can remove the thing after you get it in with a flat screw driver.
6' of socket extensions help with the upper bolts or nut's.
