no need to fill the new converter, this has been discussed to death before
when installing it you have to make sure it is seated on the pump, you should push it it and spin slowly until you hear the clunk and it drops all the way in.
Never pull the trans to the motor with the bellhousing bolts(#1 newbie mistake) If the converter isn't seated properly and you pull the trans in with the bolts you'll prolly break off the pump drive teeth.
Brendan
