Alright, so all I have to do is hookup the new torque converter. Push it in all the way and give it a little spin until I hear it pop in? Then push it up against the enine and make sure the housing goe's flush against the motor? I've also heard you're suppose to load in enough oil so the dispstick shows full then disconnect the power to to distributor and turn the motor over. Thats suppose to spread out the oil Then keep adding oil. Is this true?
