i really need some help! - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-10-2003, 01:29 PM
Post i really need some help!
the transmission in my daily driver just went out the other day.i went to the auto parts store and they sell remanufactured trannys for cheap but they need to know the distance of the torque convereter bolt.i could't really make out much of what he was saying but he said there were 3 distances'9.5,10.5,and 11.5.my transmission is in a 70 F-100 and is a c-4 with the filler tube that attaches to the pan and 26 spline.im not sure if this is common knowledge but if any one knows what it is or knows how to measure it i would appreciate it alot.even a website i could link to would be great .thanks.
Blag
Old 03-10-2003, 04:08 PM
Post
sounds like they want the measurment of the torque conv. studs that bolt to the flex plate, dont mean to question you to much but areyou sure its a c4? sounds like you have a FMX, does the tranny have a cast iron case or allum.? hopei may have been of some help. good luck JF.
Old 03-10-2003, 06:41 PM
Crosley's Avatar
Wiki Edits: 1659
Cool
You do not mention the engine size.
Depending on engine size the truck will normally have one of the two larger converters.
You need to check the size of the pilot for the crank shaft too!
I doubt the truck has an FMX since the filler tube was in the case on FMX trannys as I recall. The FMX cousin the cast-iron cruise-O trannys had filler tubes in the pans.
Many C-4's had filler tubes in the pans in Broncos, trucks, and van applications.
Tony
Old 03-11-2003, 03:30 PM
Post
what is the pilot?and where?its a 302 and the tranny's cast i belive. at least i think.yeah im more than positive its a C-4,three speed auto.thanks for the help so far,im not sure what im doing when it comes to transmissons.im new to all of it,im in the middle of an engine rebuild and then this happened.go figure,anything for this truck is worth my time.
Blag
Old 03-13-2003, 04:11 AM
New Member
Post
SOUNDS LIKE A LARGE CASE C-4.ORDER A LARGE CASE C-4 FOR A TRUCK.IF THAT ISN'T CLEAR TO THEM TRY SOMEONE WHO KNOWS WHAT THEY ARE DOING.PAY ATTENTION TO THE MANUAL SELECTOR LEVER AS THEY HAD MANY DIFFERENT ONES .SOME POINTED DOWN,SOME UP AND MANY DIFFERENT LENGTHS.GOOD LUCK BOB
