I said a headliner question was comming - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-03-2003, 06:59 PM
Bluepen's Avatar
Just a firefighter
Last wiki edit: How to title a hot rod
Last journal entry: New rear rollpan installed
Wiki Edits: 2
Wink I said a headliner question was comming
OK, I'm working on a '46 Chevy Panel truck and I said awhile back I'd have a headliner question and now the time has come to ask.
I've seen posts where you've talked about the backer board for headliners, I forgot the name of it now, and I'm at the point where I need to put some in but the ceiling in this truck has alot of curves that I need to cover and was wondering if I could use something else. I also do alot of woodworking and have got some 1/8" Baltic Birch plywood from Finland. This wood is very clear, stable and bendable and will work very good for the curves I need to cover. What I want to do is use the wood with 1/2" of closed cell foam and material. I may try to flame alittle in the front it depends on how the rest turns out first. Now can I do this or should I get the other backer board??
Thanks folks
Old 08-03-2003, 07:50 PM
BOBCRMAN@aol.com's Avatar
Usually the "Masonite" type untempered hardboards are more stable (less shrinkage and warpage from heat and humidity) and are very easy to form.
