I screwed Up Totally. CAN I FIX IT????????? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-02-2002, 06:06 PM
Arrow I screwed Up Totally. CAN I FIX IT?????????
Installed the motor like an idiot i am.
Please help me Please.
How can i get the driveshaft in
without taking off the tranny????
[ July 02, 2002: Message edited by: zeeman19 ]
[ July 03, 2002: Message edited by: zeeman19 ]</p>
Old 07-02-2002, 08:42 PM
E.T. divided by $ spent= Speed
Post
What do you mean didn't get the drivetrain to connect to the tranny?Driveshaft??
If you didn't fill the converter and the tranny is already in the car.Put like 5qt. of trann fluid in and start the car. Dump 2qt more in and put it in each gear till the trans engages now check the fluid level it'll probably be like 1qt low.(most turbo350s take I believe 8qt.)Don't let it run to long w/ low fluid it'll burn out the seals.
Thats what I would do,see what the other replys say.
Old 07-03-2002, 12:18 PM
Post
Sneaky,changing the post.Now I responded to a question that ain't there.
Driveshaft just unbolt it from the rear end yolk should be for bolt 2per strap.Becarefull don't let the caps fall off the sides of the U-joint or little needle bearings will be all over the place.Now slide the front yolk into the tranny then replace it in the rear yolk and bolt it up.
One thing look at the splines on the tranny and the front yolk shaft to make sure they are the same.
