"what did i do wrong. the primer was fully cured,"
but the filler or glaze coat were not fully dried, yes they do have solvents in them and there is shrinkage. Next time let them set, break the gloss off and let them fully cure before you finish blocking. Too much hardener is NOT a good thing either. Actually love the color, perfect fit for the car. |
You didn't mention how mamy coats of primer either. I like to put as many as six coats of primer and block it back again. It helps to prevent any of those scratch marks you describe.
i also like to get filler as glossy as possible with 500 or finer and not use itr unless i really have to. I love the color ,it's a pity theres no formula for it..
i named the color "Plum Crazy". i don't remember spraying the primer on a pannel at leas 24 hours after i sanded it. probibly put 4 coats of primer on but after i sanded it it was probibly down to 2. i didn,t use much glazing puddy, i was told the primer i was using was ok to replace the the glazing puddy with. so i did my bodywork all bondo, last sanded with 220 and sprayed with the omni fill primer. it worked great, it filled up all the scratches and pinholes, but maybe the guy steered me wrong?
I would say you reduced your 2k primer filler with urethane reducer. The reducer evaporated and shrunk the filler primer. After you applied your top coats, the reducer evaporated and the top coat sank into the sanding scratches.
This is a common problem with lacquer primer also. You must let the filler completely dry. I use a lot of lacquer primer to check my work when doing body work. It dries super fast, and sand very easy. I apply a light coat of black lacquer primer as a guide coat over the light grey lacquer primer. The use of lacquer primer is an asset in production shops due to it's fast drying capabilities. A car sitting is taking up space, and space costs money. With lacquer primer, you can sand it within 20 minutes. 2K primer cures slowly and you must wait as long as 3 hours to sand it. There are 2k primers available from Kirker that cures sooner, but you still can sand them for a least an hour. So regardless which filler primer you use, you must give it enough time to cure and shrink. Frank Cox Cox Custom Cars |
One other possibility. You said you didn't see the scratches until it was on a lift. My shop is not really well lit, and sometimes, when we get them out in the sun, and up on a car trailer, I see things near the bottom of the body that I could not see in the shop.
Once I knew this I started checking the lower body closer during the paint process. If it looks good on the ground, I would not stress too much.... unless it was a serious show car. |
it's not a serious show car , but it is my pride and joy, aside from my daughter! i can proudly say i did it all , and i mean all, myself! thats a very good feeling. i think countilaw is on to something, but i had sprayed my 2 front fenders in primer about a month before they were wetsanded and painted, that had to be plenty of time for it to cure? rite?
You been working on cars for 22 years???? Yet have only one picture of a piece of junk sitting in a field. If you know so much about body and paint, let see some pictures of your personal work. I've seen many people who can talk the talk, but can't walk the walk. I've been building cars for 46 years. I started before you were a wet spot on the back of the chicken coup. You really need to stop giving advice you know very little about or can not back up. You wouldn't last a week in my shop. YES, my shop, you see, I own a shop, I must be one of that 101st shop you don't know about that uses lacquer primer. Before you start quoting statistics, you need to get your facts straight. You don't think that we shop owns don't talk among ourselves. We know what we use, and usually borrow some from each other. We also know about punk kids that profess to be experts but yet are not dry behind the ears, that like to brag that they only use the most expensive products on the market. As I have said before, a production shop can't afford to let a car sit for several hours waiting for primer to cure/dry. Time is money. And Maaco uses lacquer primer and then only when they use bondo. Most of the time, they just scuff the paint with a scotchbrite pad and paint it. How else do you think they get a car in and out in the same day. Frank Cox Owner Cox Custom Cars |
DUDE, get YOUR facts straight. NOTHING I have posted is a lie. NOTHING! EVERYBODy here KNOWS lacquer is an inferior product. I don't own a shop because I don't HAVE to. See, I make more money with less headaches. That's a fact. Another fact is I don't have to post pictures to valadate what I say. I also don't use the most expensive products. I use what is PROVEN to give the best results. Like I said all anybody has to do is call ANY shop in their town and I can GUARANTEE 99% of the shops use 2k and NOT lacquer. I say 99% because there will be that one shop like yours that uses it. EVERY shop I have done bodywork or painted in have all used 2k primer. ALL. Body guys in production shops work on more than 1 car at a time. I have yet to hear anybody complain about having to wait for primer to dry. If they want to to speed up, they puta light on it and bake it. Just a fact, bubba. NOW as far as MAACO, there are 3 in the kansas city area, NONE use lacquer primer,NONE just scuff the cars and paint. EVERYONE are sanded with cheap sandpaper. All three use urethane paint. I can give you phone numbers if you want to call and check. Know YOUR facts!!!
heres a couple i have done,the blue one is my daily ,the other ...$750,000 300SL. Both restored over a period of many years ( as funds allowed.. ) .back to work now.
| Block sanding help with pics | holy85 | Body - Exterior | 9 | 08-07-2009 10:10 AM |
| sanding scratches showing | esahlin | Body - Exterior | 10 | 07-29-2009 12:42 PM |
| Bodywork - What steps to take...... | BeArDy | Body - Exterior | 4 | 07-06-2006 07:47 PM |
| Sanding single stage? | Project87c10 | Body - Exterior | 6 | 11-05-2004 12:44 PM |
