I think I have dry spray. - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-30-2008, 08:48 PM
Im spraying 2K au ss, so far Ive only painted the jambs etc.
The paint was applied about a week ago over a few days.
Some of the finishes are smooth as glass others painted on different days feel sandy like 2000 grit paper but still looks glossy, all surfaces were prepared the same only differences were they were sprayed on different days and the gun was set each time, the weather hardener and reducer was the same.
All had mist coat plus two full coats. Almost no orange peel.
Does this read like to drier spray?
Can I fix the stuff already applied by buffing?
If I repaint do I need the sand?
Old 01-31-2008, 05:17 AM
jcclark's Avatar
The Penny Pincher
Last journal entry: Hanging Bumpers
Could it be overspray that settled back on the finish
that was sprayed earlier?
Either way, you should be able to buff it out.
Give it a try and see, you may not even need to sand it first
if it's just a mist that dried on top of good paint.
And sometimes a clay bar will work good for just a
light mist
Maaco vs. At-Home Paint Job nightrain_rod Body - Exterior 127 08-26-2012 03:07 AM
Dry Spray? S10xGN Body - Exterior 18 01-10-2008 02:56 PM
Fixing dents with dry ice myth revisited. MARTINSR Body - Exterior 55 12-10-2007 06:51 PM
First paint job -- some dry spray.... pmeisel Body - Exterior 4 07-07-2005 01:10 PM
I'm good with a spray can.... what am i doing wrong! harrington Body - Exterior 21 04-25-2004 01:28 PM
