I think I need shocks - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-18-2010, 06:15 PM
My daily driver is a 98 jeep cherokee with 217K miles. It feels like the jeep moves from side to side when I hit a bump instead of up and down. I can feel just about every thing the tires go over.
Can anyone tell me how to test to see if I need to replace my shocks. I think I also have struts on either side in the front.
Any and all responses are appreciated.
Rob D.
Old 04-18-2010, 06:32 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
In the 'old days' we'd bounce it up and down, it it didn't settle in half a bounce, like go right to ride heigth when you stopped, we figured the shocks were shot. Probably the same with struts, on my old T-Bird they'd squeek and groan when the went bad. Sounds like you're rockin'and rollin' pretty good.
Semper Fi
Old 04-18-2010, 07:29 PM
killerformula's Avatar
Last wiki edit: Carburetor
Last journal entry: Clean up
Wiki Edits: 3
side to side is more of the death wobble from these cars, my 95 had that too. Test and replace front end components. If it were mine and I was going to keep it, I'd just go through the whole thing. After 220k miles there's not a single front end component that's worth keeping.
K
Old 04-18-2010, 07:38 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
I agree it needs a complete front end rebuild.
Cole
Old 04-19-2010, 01:41 AM
Bad Influence Racing's Avatar
Engine Builder/Head Porter
The "bounce" technique still works to this day.lol. Although I don't knowabout settleing within half a bounce but if it bounces without settleing within a couple bounces, it may need to be done. Also, if they are liquid filled shocks, look for leaks coming from where the shock's shaft goes into the casing. Otherwise, what everyone else has said, if it has a ton of mileage, I would do a complete rebuild with all new parts and bushings. You can upgrade to a uerathane style to help eliminate flex. Alos, try to upgrade parts like shocks to application specific shocks for best results. Don't just go with stock. Spend the money once and when you upgrade, go better.
Old 04-19-2010, 02:10 AM
I have replaced the front stabilizer bar bushings and links. I have not touched the rear stab bar yet. Don't see any leaks around the shocks;however, I do see where the shock bushings are dry rotted.
One more question, When I change say the rear shocks, after jacking the rear up off the ground, can I safely remove the rear shocks if I put jack stands under the frame rails towards the back? In other words the rear would still be supported by the leaf springs when I removed the shocks. I was going to use the same concept with the front.
Old 04-19-2010, 02:26 AM
I would jack up the truck, put jack stands under the frame, and leave the jack under the rear. Do the shocks have a mounting eye on top and bottom or just the bottom and the top is through bolted? If they are through bolted, you can just unbolt the nut and let them drop down, remove the bottom bolt and your done. The shocks with two eyes, I would do what I said above, remove the nut and you can start lowering the rear down a bit until the shocks free up to remove them. Sometimes it is difficult with them fully extended and fully compressed, so by letting the rear down slowly you can free them up to take them out. The springs will hold the rear in so don't worry about that. If the front's don't have struts and they are shocks, then they should have the top through bolt, which you just need to remove the nut, then remove the bottom bolts and it will fall out through the bottom. Now if this truck has alot of room under it and sits pretty high, you may be able to do all this without a jack and stands..
Old 04-20-2010, 09:50 PM
Wiki Edits: 3
by front end work I think you're looking at ball joints and tie rod ends. Jack the car up and grab the wheels, wiggle them back and forth, bet you'll find some play. Again, if you're having a problem with side-to-side movement shocks are NOT your problem.
K
2 Shocks or not 2 Shocks ortamenxs Suspension - Brakes - Steering 1 02-25-2009 06:33 PM
How to pick correct shocks? rwruther Suspension - Brakes - Steering 8 09-29-2008 11:00 AM
looking for stiffer shocks elcaminodragster Suspension - Brakes - Steering 9 02-11-2008 01:33 AM
Rear Drag Shocks on a Street Car? JohnTN Suspension - Brakes - Steering 2 08-09-2005 05:25 PM
What Front Shocks for a Softer Ride? Doc68 Suspension - Brakes - Steering 3 12-03-2003 08:39 PM
