I think my air compressor is shot - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-02-2011, 07:00 AM
Arrowhead's Avatar
EFI Rules and Carbs Drool
Last wiki edit: The FREE T Bucket plans
Last journal entry: Sold Everything for a new project
Wiki Edits: 5
I've been having trouble w/ the check valve for a while, but now it's to the point where I take the valve all a part and clean it real good and it's get carboned up the first time I start it (I have to take it apart almost everytime it cycles now). The valve get carboned up and won't seat properly and leaks. I'm wondering it the pump is shot and is allowing excess oil to blow by. It doesn't seem to be using any oil, but it probably doesn't take much.
Old 06-02-2011, 07:57 AM
How old is this pump? Also if you are using motor oil you need to change that to compressor oil, you can find compressor oil at Tractor Supply, Northern Tool or even Wal-Mart in the section that has those dinky little compressors.
Old 06-07-2011, 07:23 AM
Arrowhead's Avatar
Wiki Edits: 5
I think I found my problem. There was a large buildup of dust inside the cylinder head so there was a constant supply of crud to pumped down to the check valve and make it hang up. Even though I had cleaned the air filter, the dust was leaking by. I cleaned everything thoroughly and added a gasket to the filter flange so hopefully that takes care of it.
One-Shot wasup Body - Exterior 2 03-26-2005 04:40 PM
sand vs shot in a shot bag antiquecar Body - Exterior 9 03-17-2005 09:26 AM
Top shot by NOS Ian70Mustang Engine 21 03-26-2004 02:45 PM
50 shot of N20 mustang66maniac Engine 2 04-24-2002 11:59 AM
50 shot of N20 mustang66maniac Engine 0 04-23-2002 08:50 PM
