I think a valve be stickin open - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-16-2010, 03:05 PM
bigdog7373's Avatar
Of course it's fast
I think a valve mightbe sticking open
My chevy 350 sounds like it's missing a cylinder, so i took the valve covers off after replacing the spark plugs and it looks like the Cyl #1 exhaust valve itn't closing all the way, but i don't know for sure. any way to check without pulling the head?
Old 07-16-2010, 03:30 PM
bring the piston up to tdc.install fitting and do a cylinder leak down test, but in your case,a valve leak test, if shes bent she'll leak perdy good
acceleration flat spot in carb. corvettetonybone Engine 17 04-13-2013 08:31 PM
Piston notching for valve relief/clearance OHD Engine 9 09-16-2008 10:27 AM
TH400 1-2 Valve Removal Fasterstill Transmission - Rearend 7 09-12-2008 01:24 PM
DARK brown--BLACK plugs SBC Joshua Lee Engine 130 02-03-2008 09:12 AM
GM fast burn heads batman09 Engine 1 10-26-2004 09:32 AM
