I thinks it's a 409 Chevy - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-07-2006, 03:37 PM
Yesterday we were given an engine. My husband thinks it's a 409 chevy but we can't find any info on the net. I was hoping you guys can give us some links or the infor we need. The serial number we found is S219307 102280A. Thanks for info
Old 08-07-2006, 03:56 PM
Wiki Edits: 31
post a pic, if it is a 348-409, there unmistakeable, really neat looking valve covers.
Old 08-07-2006, 04:21 PM
justold's Avatar
if my memory is correct the 409 dipstick is on the right ,348's were on the
driver side.
Old 08-07-2006, 05:35 PM
Mustangsaly's Avatar
348 & 409 #s
http://www.348-409.com/
www.mortec.com
3732755.....348......59-61
3732811.....348......58
3751872.....348......58
3755011.....348......59-61
3771705.....348......59-61
3782012.....348......58-61
3788068.....409......62-63
3795623.....409......61
3798962.....348......62-65...Truck
3815707.....348......58-61
3830814.....427......63......"Z11" (4.312" bore x 3.65" stroke)
3830814.....409......63-64
3839752.....409......62-63
3839754.....409......65
3844422.....409......63-65
3857655.....348......62-65...Truck
3857656.....409......64-65
3860386.....409......62-64
3860387.....348......58
this is right that the 409 dipstick is on the right ,348's were on the
driver side.
Cubic Inch=348
Bore=4.125
Stroke=3.25
Firing order=1-8-4-3-6-5-7-2
Engine Weight=640/650lbs
Forged Crank=has round flywheel bolt flange
Connecting rod length=6.135 inches
Crankshaft mains=2.4977
Push rod length=exhaust 9.140, intake 8.772
Push rod diameter=5/16" (all)
Fuel pump push rod length=5.75 inches
Dipstick on Drivers side
Ignition timing=4 degrees B.T.D.C.
Spark plugs=AC44 (standard), AC45 (hotter), AC43 (colder)
Spark plug gap=.035"
Rocker arm ration=1.75:1
Internally balanced
All 348's were assembled at the Tonowanda plant.
Cubic Inch=409
Bore=4.3125
Stroke=3.5
Forged Crank=has bell shaped flywheel bolt flange
Connecting rod length=6.00 inches
Connecting rod weight=25.025 ounces
Fuel pump pushrod length=5.75 inches
Dipstick on Passenger side
Spark plugs=AC43N (standard), AC44N (hotter), AC42N (colder)
Rocker arm ratio=1.75:1
Internally balanced
X on block starting mid year of '62
All 409's were assembled at the Tonowanda plant.
*note, there were some blocks with CFD cast into them that were supposed to have come from the Central Foundry Division when there was a strike at the Tonowanda plant.
do the valve covers look like this ?
[imghttp://www.348-409.com/images/ref54.jpg[/img]
Mustangsaly
Old 08-08-2006, 05:44 PM
Thank You Everyone for helping me with my questions. I really think the info I got here will really help. Oh by the way great website
Old 08-08-2006, 08:41 PM
nitro_baller4692's Avatar
floppers forever
she's real fine my 409!
great and rare engine!!
Old 08-16-2006, 11:00 AM
want a 409 ?
all the info at the top & bottom of the page
http://vanderbrinkauctions.com/items...AllPhotos=True
Huge Classic and Muscle Cars and Part Auction!!!
Friday Sept. 8th and Saturday Sept. 9th, 2006 both days at 10am!
The Jon and Ann Matthias Collection
8010 Cnty Hwy. CR, Newton, Wisc. 53063
On Beautiful Lake Michigan!
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 10:00 PM
Hi. just wondering why the 350 chevy small block is so good... judgedredd Hotrodders' Lounge 78 06-25-2010 08:01 AM
9" to chevy conversion bigiron Transmission - Rearend 4 10-11-2005 10:32 PM
Chevy sending unit in a Ford Tank AnD Engine 0 05-14-2003 04:34 PM
New Member Introduction - 48 Chevy Rodder 48 Chevy Rodder Hotrodders' Lounge 0 10-20-2001 03:04 AM
