i wanna put bigger tires on but not sure if gears will handle - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-10-2010, 10:07 AM
hi im bryce and im 17, i drive a Custom deluxe 20 with a fresh rebuilt 350 bored .030 over thats pushing about 350-375hp with a rebuilt TH350 3 speed automatic and a NP 203 transfer case thats 4 WD all the time. i also have a GM14 bolt FF rear w/ 4.10 gears and a Dana44 w/ 4.09 gears up front. i dont know what size tire yet cause im not sure what it can handle without getting new gears. any suggestions would be greatly appreciated. thanks
Old 06-10-2010, 10:28 AM
38s will work ok
Old 06-10-2010, 10:54 AM
big gear head's Avatar
High Performance Rear Ends
Try this. http://www.ringpinion.com/Calc_RPM.aspx
Old 06-10-2010, 03:43 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
How much lift do you have on it now and what are you thing on with the lift?
Is it your D/D? or just a play toy?
Cole
Old 06-11-2010, 10:16 AM
It actually doesn't have a lift on it but it's already pretty tall for stock but when I get money I plan on maybe getting a 4inch at most...cause yes it is my daily driver, but I would like to take it out every now and then for some fun
Old 07-08-2010, 04:36 PM
Last journal entry: 81 regal swap project
tires
you might be able to squeez 33s without the lift but the gears you have will work best with 35s but if you wanted 38 would be ok.
Old 07-08-2010, 05:53 PM
57halfton's Avatar
I would do 35's or 36's with a 4 inch lift. I had a 79 Chevy 4x4 halfton a while back with 36 inch tires and 3.07 gears , but took out the 350 and put in a 454. That combo worked great for me, more torque not lower gears.
Old 07-08-2010, 06:20 PM
33" BFG's with 4-inch lift. Was using the original 3.08's. Like the others suggested 36-38" with your 4.10's should be good.
Old 07-10-2010, 10:17 AM
go big or go home..lol...IMO.....but seriously, with 4.10s you can run 38" like nothhing...as for a daily drive, 33-12.50-15, nice looking tire...
remember a truck looks better with the fender wells fulll then a truck 20 feet off the ground and diffs draging...IMO
bigger tires hotrod66_57 General Rodding Tech 2 07-23-2004 01:37 AM
What size wheels and tires to put on my 85 Silverado? leastbay Hotrodding Basics 1 06-15-2004 02:11 AM
What size wheels and tires to put on my 85 Silverado? leastbay Hotrodding Basics 0 06-14-2004 05:54 AM
Do I have to shorten the rearend to fit bigger tires? fireschenie Transmission - Rearend 7 12-26-2002 12:45 PM
Bigger tires Speed-o-meter is off CompFX Transmission - Rearend 9 10-18-2002 12:56 PM
