We're winning the case!
Hotrodders Bulletin Board > Tech Help > Electrical
  #1
Old 08-24-2004, 06:00 PM
batman09's Avatar
batman09 batman09 is offline
CLICK ON MY AVATAR
Question I want to install an underdash ignition kill switch in my 67 nova...can you help?
I want to install an underdash ignition kill switch in my 67 nova...can you help me?The ignition has 4 wires coming out....1 red,1 pink,1 purple with a white stripe,1 brown with a white stripe and 2 smaller wires.I was wondering if I could cut one of these wire and splice in a toggle kill switch?Any help would be greatly appreciated!
PS if I can do this what guage wire shoud I use?thanks bm
Old 08-24-2004, 06:55 PM
docvette's Avatar
docvette docvette is offline
docvette's barnstar
Wiki editor
Last wiki edit: Rebuild an alternator
Wiki Edits: 12
Kill Switch
[color=yellow][size=2]Doc Here
The wire you want is brown. (See Attachment, Schematic for your Car)
Th Gauge wire will be exactly the same as provided with the stock harness gauge or better.
Be advised, this switch must always be in the "ON" position for normal operation. If it accidentally get knocked off, you may end up looking for problems you don't have.
I always recommend, From past experience, If your not using the switch as anti~theft protection, use a lighted switch, so you will know it's on and operating, Or better yet, get a double throw, single pole, switch and on the "Off" side of the terminals hook a Buzzer different sounding from the car's stock buzzers so you will know when the kill switch is off, before you go looking for a bad Ignition, or dead fuel pump...
Or at least a 12 volt red led mounted on the dash...
Hope it helps
Doc
[/color][/size]
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 08-24-2004, 06:57 PM
docvette's Avatar
docvette's barnstar
Wiki editor
Wiki Edits: 12
sorry..
forgot the attachment....Silly me...It's just tough gettin' olde..
Name:  67-8 ignition.jpg
Innovations
Old 08-27-2004, 03:38 PM
1974 gto 1974 gto is offline
i was wanting to do the same thing. i put an aftermarket Crane cams X-RI ignition conversion on my 1974 gto. what wire would i use?
Old 08-27-2004, 04:04 PM
docvette's Avatar
docvette's barnstar
Wiki editor
Wiki Edits: 12
wire
[color=yellow][size=3]Doc here
You want the wire that comes off the run side of the ignition switch. Or the wire that supplies 12 volts to the coil.
If it's like the Chevy schematic above, it should be brown.
Hope it helps!
Doc
[/size][/color]
Innovations
Old 08-27-2004, 05:52 PM
LanceM LanceM is offline
Almost an old guy...
If you are using it as a theft deterrent, I figure that anyone that want's it bad enough is going to get it but might as well make them work for it , anyway since I don't smoke I use the cigar lighter as the switch. A little work with solder and a penny and pushed in you have contact, pulled out in the normal popped position and it's off. I figure nobody is going to wait for a lighter to pop while they are trying to steal a car and there are no extra switches " to be found", if you are leaving it where you'd rather not pop the lighter or better yet take it with you!!
Old 08-28-2004, 03:01 AM
docvette's Avatar
docvette's barnstar
Wiki editor
Wiki Edits: 12
KEWL!!
[size=3]Doc here
That's an innovative idea...never heard of it before but sounds like a neat trick!
Hopefully the Lighter never popped out on ya going down the road...Murphy is my A Driver...
Doc
[/size]
Innovations
Old 08-30-2004, 07:56 AM
BillyJoe's Avatar
BillyJoe BillyJoe is offline
I did the same thing with the cigarette lighter except I put a push-on push-off switch from radio shack at the bottom and just use my finger to activate. It's connected to the Park/Neutral ignition lockout on the transmission so in the off position it thinks its in gear and won't start.
Old 09-10-2004, 07:02 PM
gemini86's Avatar
gemini86 gemini86 is offline
Hey, mine's paid for, Punk.
Now wait a minute, I think I missed something... How did you keep the lighter from heating up and popping out? That's a pretty sweet idea...
Old 09-10-2004, 07:17 PM
Rhansen's Avatar
Rhansen Rhansen is offline
Footbraker
when I had a car with an electric fuel pump I would just pull the fuse to the pump.
Old 09-10-2004, 09:01 PM
lori-due lori-due is offline
I bought a battery disconnect switch that is installed between the negative battery cable and the post.---The switch has a nobe on it that one can remove which makes it impossible for any-one to start or take the car....Good luck...
Old 09-14-2004, 03:17 PM
matt_ramsey's Avatar
matt_ramsey matt_ramsey is offline
Your Basic Moron
when I put a kill switch on my HEI setup, I ran a nice fat power wire to a high-amp headlight relay that you can get at auto zone, and switched that on and off. That way I bypassed all of the old 1964 "points" wiring (and the resistor wire) and didn't have to run my power wire in and out of the passenger compartment.
Old 09-15-2004, 11:08 AM
Gemini86,
Take out the heater coil and solder in a couple of pennys so that they make the contact when the lighter is pushed in. This becomes a grounding switch so you can use it to close a relay or use it to ground out the ignition when it is pushed in.
Lance
Old 09-16-2004, 03:16 PM
docvette's Avatar
docvette's barnstar
Wiki editor
Wiki Edits: 12
anti steal...
[size=3] Doc here
Back in the days....
Before HEI........
The best anti theft system.......
Was cheap and easy............
Pull the coil wire and take the rotor with you! LOL
Doc
[/size]
Innovations
Old 09-16-2004, 06:09 PM
solidaxel's Avatar
solidaxel solidaxel is offline
Yes I remember those days, as I would just pull the coil wire also. Then someone stole the car and when I found it ,it had one spark plug removed and shoved into the coil and distributor, and it ran on seven cylinders until it ran out of gas !!!
Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
