☻I want to loose some weight☻ - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-15-2009, 06:45 PM
DENCOUCH's Avatar
I have a '74 chevy 1/2 ton & a GVW of 4200 lbs, I would like to shed a few pounds. Would there be a practical way to trim off about 500 or so? I am ready to give up being a "heavy hauler", and don't plan on going after any sand or gravel anymore.
Up front all I see when I open the hood is the huge front suspension pieces. The huge and HEAVY front suspension pieces! Do I need stuff built this stout? Could I ditch the front bumper & hardware? If so, how do I clean up the wound that is left with the bumper gone?
I have ditched the power steering & gone manual steering. I don't have power brakes, nor a/c. The jack & spare are gone, and I have an abbreviated exhaust system.
Any suggestions?
Thanks!
Old 06-15-2009, 06:50 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Is that a tommy lift on the back in your pictures, If it is it has to go. You can buy fiberglass bumpers also or a roll pan for the back. Cole
Old 06-15-2009, 07:22 PM
BigBlockT's Avatar
Last journal entry: recessed lisence plate
chop the rear frame and resection it and put a short box on it , maybe try a fiberglass dog house if you want to be different go all fiberglass I thought there was a company on the net that sold fiberglass cabs,beds. just my 2 cents good luck.
Old 06-15-2009, 08:22 PM
GVWR is not curb weight. A short box will lighten it up and make it look better.
http://usbody.com/ sells fiberglass parts and complete bodies but you're getting into big bucks there.
Shane
Old 06-15-2009, 09:30 PM
DENCOUCH's Avatar
Ditch the pounds
Originally Posted by F-BIRD'88
Swap the motor+trans into a lil S-10 or Ford Ranger, or Toyota/Nissan/Mazda pickup. you need to ditch 1000 lbs.
Originally Posted by BigBlockT
Chop the rear frame and resection it and put a short box on it , maybe try a fiberglass dog house if you want to be different go all fiberglass I thought there was a company on the net that sold fiberglass cabs,beds. just my 2 cents good luck.
I ditched the liftgate & one can really feel the improvement in zip! This is what has served my interest in getting my truck on a diet. Today UPS dropped off a set of Lakewood traction bars and a set of 4.11's. Now I can ditch my old 3.40's. I should feel this change, I believe, no? I am thinking I would like a fiberglass hood and perhaps wheel wells.
What has my interest is perhaps knowing of some lighter front suspension & steering gear set up that would save me some weight up front.
Old 06-15-2009, 09:47 PM
fast68's Avatar
likes chevy trucks & boobies
GVW is not the weight of the truck
go weigh the truck on a gravel pit or scrap metal scale to find the actual weight of the truck
what it says on the sticker or plate on the door frame or door is not the trucks actual weight
earlier years trucks were actually lighter than the 73-up ones
the 64-72 years longbed 2wd's were average of 3850lbs actual weight
GVRW was 5000 to 6000lbs
suspension pieces arent that heavy
altogether with everything it is all heavy yes
but individually they are not much weight
i once weighed and entire 2wd longbed bare frame just out of curiousity, i cut it up into pieces and stacked on the digital scale. this was back in the day when i had about a dozen old trucks at any given time and was parting and cutting up ones i wasnt driving or swapping engines into.
i got 200lbs for entire bare frame weioght
the bare front engine cradle suspension crossmember 75lbs
the control arms are lighter than this by far
bare 12 bolt axle housing 75 lbs
the 73-up bodies are heavier and larger than the 72 older ones
thats the difference mainly.
front bumper you have to have legally it is safety equipment
same with rear in most areas.
check local laws though
eliminaye a/c and convert to a/c delete from a donor truck.
put in light weigh buckets from a car or minivan etc or use aftermarket ones
there are many things you can do still to cut off weight
aluminum intake also.
remove inner wheel tubs
fiberglass parts of course
aluminum raidator
remove sway bar equipment if so equipped
have fun
Balancer loose on crank powerrodsmike Engine 22 06-13-2009 01:15 AM
TH350 sun shell, loose... CamSweet Transmission - Rearend 2 01-31-2008 05:23 PM
loose input shaft fireguy Transmission - Rearend 2 11-26-2004 08:34 AM
Loose Harmonic Balancer in 350 Hot_Rod_Faith Engine 2 07-03-2003 11:52 AM
HELP! New timing set too loose dran04u Engine 1 06-26-2003 05:14 PM
